Question about exterior lighting problems w/ Kenworth W900 2007
Discussion in 'Kenworth Forum' started by tatercake58, Mar 3, 2013.
  1. tatercake58
    tatercake58 Bobtail Member
    Hello too all out there Im new too the forum I go by tatercake58 and I have a question about the lighting on a Kenworth W900L 2007 I started experiencing lighting issues where my LED's were acting up when I would be hauling and put my flashers on everything would go crazy turn signals would stick on, sometimes go out, I would loose all lighting and when they would return only partical power would be there and an unusual thing would happen when I would shut all lights off 1 or 2 LED's would stay lit, we replaced the power box in the dash that has control of all the power circuits but still no good still have this same problem and Kenworth is unable too tell me what further too do so if any other Kenwood owners out there have experienced this problem and was able too solve their problem please let me know what you found and what you did, oh I also changed the turn signal switch on the colume nothing changed my problem, so if any one can help I would appreciate it very much. Thanks
  3. d o g
    d o g Trucker Forum STAFF Staff Member
    24,449
    53,299
    Sep 20, 2010
    Texas
    Welcome to the forums, tatercake. Let's move your post to the KW forum so that the W9 experts can help you out.
  4. oneperfectrun
    oneperfectrun Light Load Member
    131
    47
    Dec 18, 2010
    Fulton, MS
    I would be willing to bet you have a ground problem somewhere. I had an issue with my 03 w900
    last year where my headlights would go out and usually at the worst possible time. Started out going out when I would brighten or dim the lights. I thought it was in the turn signal/dimmer switch so I replaced that and problem stayed. I looked and looked for a cause and finally gave up thinking I would just have to wait for them to go off and stay off before I could find the problem. Well they finally did and I started checking everything with a light tester. Long story short I had a ground wire going to the right front fender maker light that was broken and barely making contact. Fixed that wire and not one problem with headlights since. Grounds can do some strange things sometimes!
  5. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Do you have fog/driving lights as well? We have seen a failure in the head light/front lighting harness connector (located near the back of the trans) the two ground pins can't handle the extra amps and burn out, have had to cut open some plugs that were melted so bad. Best thing to do is at the front end where the head light connectors are, take the white wire (ground) and with enough slack, cut it and put a ring eye connector on each end, then connect to a good ground, may have to drill a hole and use a small bolt/nut, do this to each side, cuts down on a lot of front end lighting issues.
  6. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Replace your pigtail going to the trailer.
