Question about exhaust clamps
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Sep 22, 2015.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    I am redoing the exhaust on my Int'l 9400. ( that's a whole nother story). All that's left to do is install a 21" section of flex pipe between the turbo pipe and the exhaust pipe under the cab. Each pipe has a notch 3" from the end to limit how far the flex will slide up on the pipes.
    My question is; what is the best clamp to use on the flex to solid pipe joint?
    I have formed and flat band clamps, or is there a design out there that would be better. It is a very tight area to deal with them. I need to hurry on this so any help is much appreciated.
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    You want to use a stainless step clamp, not a flat clamp. Put some muffler cement it will help seal better.
    If is really tight you might want to look for the clamp without the nuts. It's a bar inside the clamp with threads on it. I think walker makes them
    silver dollar Thanks this.
  4. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Make sure your use a stainless flex pipe too.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    AutoZone sells em for $15.
    heavyhaulerss Thanks this.
  6. rollin coal
    rollin coal Road Train Member
    13,083
    25,868
    Mar 29, 2008
    TN
    Second the stainless flex and stainless preformed bands are also what I use. I tighten the piss out of them until they bottom out. None of mine leak.
