Question about chain
Discussion in 'Flatbed Trucking Forum' started by RStewart, Aug 14, 2019.
  1. RStewart
    RStewart Road Train Member
    3,163
    5,024
    Aug 21, 2015
    Norman, OK
    Yeah, I know, another one. Lol. I did a search and didn't really find the answer to my questions. If you don't mind answering that would be great...
    When it comes to equipment and general flat/step freight:
    How often do you have a need for chains longer than 15ft on loads?
    How often could you get away with using 10ft chains on your loads?
    Reason being my questions is I was thinking about getting 8 25ft chains and cutting them into 15 & 10ft pieces. But I figured before I make those kinds of plans if come ask the experts.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Needing a 25 foot chain will be rare. I always have some 16 foot chains, and I always keep some short ones on there too. I have some 24 foot chains, and actually they are more of a pita, I just keep one on a truck usually.
    One thing, it really doesn't matter how often, what counts is will you have what you need when you have to have it. I tended to carry more gear than I USUALLY needed, but I had it when I did, USUALLY. lol
  4. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    Hauling steel roofing trusses, long chains are almost a must. Unless you feel like a monkey and are of a mind to clamber 10' up placing strap protectors.
  5. beastr123
    beastr123 Road Train Member
    2,805
    22,861
    Jan 2, 2014
    Moose Jaw SK CAN
    I carried 2 25'and 30' chains to use as belly rap/ choker chains for pyramid loaded pipe. They were 5/16 gr7. The rest of my chains (12 of them)were 15' 3/8 g7.
    The 5/16 were also good for top chokes on split coils and for 1 chain 2 binders on light equipment such as small tractors
  6. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I haul a lot of pipe, but use straps instead, I do have long straps to belly and butterfly wrap it.
    Lepton1 and RStewart Thank this.
  7. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,600
    Oct 6, 2009
    Colorado
    we have 20' chains and I've been short a couple times. (and learned to carry a few shorties). The 20' seems to be a good overall choice for "stuff". For equipment I"d want shorter.
    RStewart Thanks this.
  8. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    I used 20' chains. I think 15' would be a bit short too often. I can't imagine 10' unless it was for hauling equipment on a step-deck. but then again a 20' is good for two direct tie downs if you throw one end across the deck and use the ends as direct tie downs.
    20's were nice for coils, if you have a rubrail/anchor that can hold a binder hook. just throw both hook ends through the eye and you just threw two chains through the eye.
    Hard to say. I suppose you could just hook a short chain on if you ran out of length. but a 20' isn't bad to pack around.
  9. RStewart
    3,163
    5,024
    Aug 21, 2015
    Norman, OK
    I think I'll stick with 20ft chains. I never thought about throwing the two hooks through a coil and it equaling two chains. Makes sense though. Good point.
    singlescrewshaker Thanks this.
  10. Razororange
    Razororange Road Train Member
    2,453
    23,211
    Dec 20, 2011
    Milwaukee, WI
    I carry nothing but 10ft chains. Used to carry all 20s but I almost never need a 20ft chain. Got tired of humping around so much extra chain and cut them all in half. If I do get into a situation where I need a 20+ ft chain I can either hook them together or use midlinks to connect as many 10ft sections as I need for a load.
    kylefitzy, Diesel Dave, cke and 2 others Thank this.
  11. JonJon78
    JonJon78 Road Train Member
    7,042
    37,579
    Jul 1, 2018
    Are you going to be pulling a step or flat?
    Lepton1 and 4mer trucker Thank this.
