Question about CDL Photo
Discussion in 'Experienced Truckers' Advice' started by TomFriendly, Sep 13, 2022.
  1. TomFriendly
    TomFriendly Bobtail Member
    4
    Hi,
    I had a customer recently use his CDL as an ID for a credit card. I noticed on the actual drivers photo that he had a 6 digit number running vertical up the left side of the photo. The number doesn't correspond with anything else within the license and I don't recall ever seeing that before on a CDL. I wrote it down as part of the ID but I'm not sure if I needed to or what it means. Anyone familiar with that?
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    what state was he from?
    each state has different looking licenses.
  4. TomFriendly
    4
    This was a Nevada issued CDL.
  5. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    Without knowing what your business is or why you're needing to write down info from someone's drivers license, I'd say if you don't know what it is, you probably don't need it. If your business required it, you'd know it. But, I'm skeptical of a need to write down any information from the drivers license. FWIW, my Texas license does not have any number across the picture.
  6. TomFriendly
    4
    Thanks for your answer. So in Texas there is no number on the photo? As for the business, nothing crazy. It's a credit application for a gas station card and that was the ID. We usually have the customer fill it out and then we verify the info but I wasn't sure what that number was for so I added it as a foot note.
  7. Terlingua
    487
    1,019
    Oct 24, 2021
    No, there's no number on the photo. If I had to guess, it's probably similar to what Texas calls the audit or DD number. It's a number on the license that's different from the DL # that if you know how to decode it tells you information about when and where the license was issued.
  8. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    are you talking about the numbers , 1,2, 8, 15, etc...etc..????
    if so, those are DMV codes, even my non CDL license has those too......
  9. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    CA has you mm/dd/yyyy raised not printed on bottom of picture
  10. TomFriendly
    4
    No it was actually on the larger photo itself and ran vertically up the left side. I don't see it in that photo.
  11. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    well i dunno, i checked, "provincial", "temporary", "undocumented resident", "probationary", "undocumented alien resident", i got nuffin else to offer.
    i'd say flag that application as a fraud.
    make the guy provide proof it is real.
