Quality of Delco 39mt starters
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Motto, Jun 1, 2020.
  1. Motto
    Motto Light Load Member
    102
    126
    Apr 10, 2020
    Quality of Delco Remy 39mt starters are bad. I keep changing them on DD15s. The latest pn 8200424 worked only 1.5 years. Did anybody have teared it down to see what is the problem inside? Anybody used Denso poweredge starters on DD15 ? If yes are they good?
  3. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Most times it is just the small solenoid on them that fails. It can be replaced separate from the starter.
    Motto, Shawn2130 and wore out Thank this.
  4. Motto
    102
    126
    Apr 10, 2020
    You mean the ims that goes on top of starter or the solenoid switch?
  5. pushbroom
    1,777
    7,253
    Sep 1, 2012
    Red is small solenoid. Blue is big one.
    Shawn2130 and Motto Thank this.
  6. Motto
    102
    126
    Apr 10, 2020
    I have two brand new delco starters. I will change the small solenoid to see what is happening...
  7. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I’ve installed 2 of those. One on the freightliner, works good so far.
    Installed one on the ford, got maybe 3 months, dead. changed the little solenoid, nothing.
    Switched back to using rebuilt slow turning starters of the past.
    Took the 3 month starter in to be checked. The big solenoid was burned. Not sure why.
    650cat425 and pushbroom Thank this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I just replaced mine this weekend.
    The starter motor housing was coming loose from the mounting flange. Those two really long thin bolts that run along the outside of the casing weren't tight enough.
    Motto Thanks this.
  9. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Were the starters you got rebuilt or brand new? The ones that are rebuilt are sent overseas and only the parts that failed are replaced, the sol. that are put on are known to be junk.
  10. Motto
    102
    126
    Apr 10, 2020
    I have purchased them at freightliner dealer. Brand new Delco Remy. The label says made in mexico.
  11. Motto
    102
    126
    Apr 10, 2020
    btw freightliner has mitsubishi starters. They are little expensive.
