Qualcomm Fuse
Discussion in 'Experienced Truckers' Advice' started by JC1971, Jun 4, 2016.
  1. JC1971
    JC1971 Road Train Member
    2,607
    9,312
    Jul 29, 2013
    L.A.
    Does anyone know where the fuse for the Qualcomm is typically located? Another time it was out, I asked the tech and was told "behind the dashboard", presumably to keep drivers from yanking it if they're about to run out of hours. I've been sitting and waiting to get into the shop since Friday morning and they're not going to get to it until Sunday so I'd like to see if it's something easy to fix and get out of here.
    Kyle G. Thanks this.
  3. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    Depends on what kind of truck you have, ..
    What's the Quallcom doing? Maybe hold down one of the buttons to reset it
  4. JC1971
    2,607
    9,312
    Jul 29, 2013
    L.A.
    It's a 2013 Cascadia. No power. I went to sleep and it was fine and woke up with no power to it. I checked the power plug where it plugs into the electronic unit located in the sidebox and it was still plugged in.
  5. tucker
    12,647
    40,422
    Jun 13, 2008
    IN
    That fuse box is behind the glove box, should have to remove 4 torch head screws to get to it.
    I'd be under the bunk wiggling every cord to the brain of it too. Unless I wanted the day off
    JC1971 Thanks this.
  6. JC1971
    2,607
    9,312
    Jul 29, 2013
    L.A.
    Well, it is 112 in PHX right now. Don't want my tire treads coming off. Maybe wait until nighttime to leave if it works.
  7. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Day off???
    Heck no!
    That's the day to break out the coloring book... er, paper logs, and get in some SERIOUS miles!
    tucker Thanks this.
  8. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    Like they said, remove screws to glove box. On the glove box or on the plastic cover that sits over the fuses will tell you fuse locations. It will say "fleet management " on the fuse you want. If your having QC problems you can pull the fuse and wait couple minutes then install it and it will re-boot the system.
    JC1971 Thanks this.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    This.
    You are required to have a paper log as backup anyway, does your company prohibit it's use?
    Lepton1 Thanks this.
  10. Kyle G.
    Kyle G. Road Train Member
    3,759
    19,631
    Jan 23, 2016
    Eastern Iowa
    I drive a '16 cascadia with people net. Not sure about Qualcomm, but try checking in the front of the battery box, which should be under the catwalk.
  11. JC1971
    2,607
    9,312
    Jul 29, 2013
    L.A.
    It's fixed now. Thanks for the replies. I pulled the fuse and replaced it. Also, pushed in hard on the cord going to the QC and it came on, so I'm not 100% sure what it was.
    I just came out of hometime and I didn't want to run the next 3 to 4 weeks on paper logs and having to call in to load and empty and get load info. Especially with the DOT blitz coming soon. I think I'm alright with paper logs, they look pretty good the few times I've had to do them, but I'm not completely confident that they'll pass DOT scrutiny.
    It just sucks that I sat here for 1 1/2 days for nothing, but the shop told me that it would probably be that afternoon that the truck would get in Then they said the next morning. Then this morning they said tomorrow, but I'm probably not telling anyone what they haven't experienced before with a megacarrier.
    tucker and Lepton1 Thank this.
