Qualawash deaths
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by mustang190, Jan 19, 2024.
Page 1 of 3
So many times the second person goes emotional instead of prepared for confined space entry making a double fatality.
So sad when this happens.Flat Earth Trucker, mitrucker, homeskillet and 1 other person Thank this. -
Very sad of course. But this happened over four years ago.
Flat Earth Trucker Thanks this. -
Flat Earth Trucker, Magoo1968, MACK E-6 and 2 others Thank this.
Flat Earth Trucker and RockinChair Thank this.
This happens 1-3 times almost every year in the Houston area. There was a dupont plant where 4 where layed out by poisonous fumes. If SOP's were followed. It would have only been 1. And whats really sad is that two of them were brothers.
Seems Osha would have cracked down by now. And local tank washes would have more safety measures in place. But it keeps happening.Flat Earth Trucker and JoeyJunk Thank this. -
2 things tend to happen in Houston every year. A plant fire/explosion, and a plant or tank wash worker passing away from chemical fumes or inhaling nitrogen. Some places require H2s monitors. Or some companies only provide 02 monitors. But with a multi monitor one can be alerted of danger of breathing in the wrong thing. And get away quickly from the area. However the multi units cost $$$ and companies aren't willing to spend. So they cheap out and by monitors that only detect one thing.Flat Earth Trucker, scythe08 and gentleroger Thank this. -
Last tank carrier I worked at had a huge A frame on wheels with a pulley connected to an industrial retrieval winch...looked like a fishing rod on steroids.
After air testing any tank entry was in harness connected to this device with an attendant waiting to crank them back to safety.
Was used for mostly internal inspections by the shop.
This is the minimum in my mind for any tank entry.Flat Earth Trucker and gentleroger Thank this. -
Problem with nitrogen is its heavier than air and doesn't waft off out of tank. That and it kills people instantly
Page 1 of 3
