pyrometer/egt install
Discussion in 'Freightliner Forum' started by truckerbangin, Jul 16, 2013.
  1. truckerbangin
    truckerbangin Light Load Member
    262
    44
    Jan 22, 2013
    i'm running a S60 ddec iv 12.7L and i want to intsall a pyrometer/egt guage where is a good place to install the probe for the pyrometer/egt?
  3. Gasienica
    Gasienica Heavy Load Member
    924
    528
    Sep 7, 2011
    4 inches after the turbo in the down pipe.
    Rawze Thanks this.
  4. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Do you have a boost gauge? That would be a much more helpful / useful addition if you don't have one already.
    Rawze Thanks this.
  5. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    As said, @4" down from the turbo on the "S" pipe on the exhaust side.
    Remove the S pipe, drill the hole for the bung, weld in the bung, refit pipe, insert sender unit, wire in.
    If you also need a turbo gauge, get a mechanical one and fit the hose to one of the blanking plugs in the intake manifold.
    Martin
  6. nikkiandstephen
    nikkiandstephen Bobtail Member
    23
    5
    Aug 6, 2013
    most stock freightliner fld120 and classic you will find the pyro needle mounted in the turn pipe off the turbo. freightliner finally after years of begging sells a kit with the gauge needle wiring mounting nut for easy install in a fld or classic. hope this helps
