Putting Alcohol in the Brake Lines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by anothercupajoe, Jan 4, 2014.
  1. anothercupajoe
    anothercupajoe Bobtail Member
    24
    10
    Nov 24, 2011
    Minnesota
    Hi everyone,
    I live in a freezer - no seriously. The other day my trailer brakes froze up and the mechanic that showed up to help pulled a length of hose out with a glad hands connection on either end and in the middle was a female connection to screw a quart of alcohol into. He pushed that quart into the brake lines inside a minute. I'm not kidding - a freezer - it took 2 quarts and 40 minutes before the brakes broke free.
    So where would a guy find the doo dad with a nipple on either side for hose connect and a threaded doo hikee that a quart bottle would screw into?
    I know; I should've asked him. I also should've bought Apple at 10.00.
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    You live up on the iron range?
    if you freeze up a lot you may need a new dryer.
    You could get a glad hand with a short line and somehow put a funnel on the end?
  4. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    First try bleeding your tanks. If your dont and it keeps building up it will freeze up your dryer to and it wont release air pressure. Now your looking at putting alcohol straight in to the air compressor.
    anothercupajoe Thanks this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I don't know where you'd get one, but it's not good to use airline anti-freeze often, it's hard on air bags and chamber diaphragms. It has its use for emergencies, but if you have to use it often, you may need to service or replace the air dryer. Make sure the air dryer heater is working and drain your tanks often. If you live where it gets really cold, an air dryer upgrade is a good idea, like a dual cartridge one.
    It's also not good to use it in the blue line. If the blue line is frozen, you should pull it off the valve(s) so you can blow the alcohol through, then hook it back up. It wont get water out since it has no where to go. Once the alcohol evaporates, it can freeze up again.
    Another thing to check is your air compressor coolant hoses. Cats are good for the steel braiding rusting up. I've pull some off where the inside diameter of the hose was about 1/2 of what it should have been or the rubber was coming apart clogging them up. A hotter compressor makes more condensation. If the hoses are brittle, cracking or swelled up, replace them.
    anothercupajoe and KW Cajun Thank this.
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Most every truck dealership should carry air line antifreeze it is suppose to have some kind of lube in it, Personally, you can get Menthol Hydrate at a hardware store, pore it in the emergency line, on the truck , connect the line pore some in the service line and connect it, charge the trailer and apply the brakes. The air system you have to drain the tanks all year long when ever you are parked on an incline drain the tanks that the drain is at the low end. Drain the trailer tanks as well.
    Once it is cold out and the system has not been maintained it is a little late, Preparation, and maintenance does work.
    Just a thought!
    anothercupajoe, Joetro and 88 Alpha Thank this.
  7. anothercupajoe
    24
    10
    Nov 24, 2011
    Minnesota
    Hey thanks for that. I was thinking about this in the wrong way. I did only want to have the ability to add anti-freeze in this way in emergency situations. Now that its frozen outside and there isn't much I can do - without getting it in and warming it up to dry it out - I was still wondering if maybe someone had seen an appliance like the mechanic's Super Anti-freeze Injector.
  8. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    You could just use an empty gear oil quart container, they have the spout that you can stick a hose on connected to a gladhand.
  9. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
  10. anothercupajoe
    24
    10
    Nov 24, 2011
    Minnesota
    One would have thought since the truck was delivered brand new to this cold country that it would have had an anti-freeze in-line tank as a matter of course.
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Bendix used to make those but not any more probably because they frown on adding anything to the brakes system.
