Putting a C27 or C32 in a truck
Discussion in 'Questions To Truckers From The General Public' started by petefan4000, Mar 28, 2021.
  1. petefan4000
    petefan4000 Light Load Member
    107
    129
    Dec 2, 2020
    I know I'm gonna get flamed for this, but...
    Would a C27 or C32 fit under the hood of a 389? If so, what would it take if one were to (hypothetically) do it?
    Part of me says "no" but another part of me says "yes you could do it but you'd have to relocate a bunch of stuff." In the latter case, you'd need different exhaust manifolds (because the industrial C32's have the turbos sticking out the sides) as well as remote mounted filter housings and custom engine mounts. Obviously doesn't seem all that realistic but I just want to have some fun.
  3. AModelCat
    154,281
    A C27 is more or less an evolved 3412.
    Brettj3876, Magoo1968 and petefan4000 Thank this.
  4. petefan4000
    107
    129
    Dec 2, 2020
    Another thing I've noticed is that on Cat's 2019 (industrial) engine rating guide, the C27 and C32 are listed as being 76% wider than the 3412. Is that just because of the manifolds, accessory mounts, filter mounts, and whatnot, or is there something else?
  5. roundhouse
    roundhouse Road Train Member
    3,129
    7,026
    Jul 11, 2018
    I’m not sure of the exact measurements but the hood on a Ford LTL 9000 is a lot wider than on a Pete or kw
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Hot #### look at the size of the manifold on that beast :eek:
