push to connect fitting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Nov 20, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Found a small leak when installing my air dryer IMG_20181120_202722.jpg on this fitting I believe its 1/4" tube x 3/8" threads it was barley leaking so I gave it a fresh straight cut anyway and now it leaks a lot worse should of left it alone. O ring was cracked and dry rotted,so replaced the o ring but theses o rings are a little different then normal o rings reinstalled
    fitting and still leaks.Where can I buy this and other connect fittings? No parts stores around here sells these kind of fittings... Frustrating. Thanks guys.
  3. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    Try a welding supply, or plumbing supplier. Not joking, those guys carry the strangest things. Especially when it comes to brass fittings.
  4. lwlevens
    623
    427
    Feb 9, 2018
    Thanks, was thinking of going to home depot but it needs to work with 120 psi.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You must use DOT brass on anything air brake. Every heavy truck parts house and truck dealer across the globe should have these on hand. Try Parker store or hydraulic parts suppliers for stock of proper hose and fittings. I would guess your fitting in question is 1/4 x 1/8"npt. A traditional compression fitting will fit in its place just the same.
  6. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
  7. lwlevens
    623
    427
    Feb 9, 2018
    Thanks 3/8 npt goes in the air compressor governor.
  8. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    Not true- they have come out with composite fittings that are just as durable as the brass- (Elbows-unions-etc) Actually I was skeptical at first- But now,I replace any airline fitting with the comp ones
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Every port on the governor is 1/8" NPT, not 3/8"
    spsauerland Thanks this.
  10. lwlevens
    623
    427
    Feb 9, 2018
    Really I measured the width of the threads with my calipers and it was 10 mm which I believe is 3/8 ?
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    PTC fittings all seem to leak! Hard to beat compression fittings. One in picture to a compression would a VS269NTA4-2.
    snowman_w900, Oxbow, SAR and 2 others Thank this.
