Purchased 2 Michelin Energy for my steer, and they’re Out Of Round!
Discussion in 'Ask An Owner Operator' started by Dok2304, Jul 11, 2022.
  1. Dok2304
    Dok2304 Light Load Member
    185
    49
    Sep 19, 2013
    I’ve purchased 2 new steer tires for my truck, and they spin them at the alignment shop, and show me they’re out of round.
    I’m shocked, Michelin tires out of round , I can’t believe it . If Michelin is bad , then what brand is good. I saw it, but I just can’t believe it. I know it’s no way to fix this, but anybody else had this problem.
  3. jamespmack
    213,482
    They have blems to. Normally does not make it to market. Used to buy their blems for multi axle trailers. Cause they were still a Michelin and you couldn't tell. Who ever sold them to you should take them back no problem. Normally they would not ship a bad tire. But can happen.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    What size? Bigger tire can sometimes get mounted crooked. Try to break them down and spin 180 on the rim. Make sure the beads are lubed good.
    Sounds impossible, but I have seen it. Especially on bigger sizes.
    Also make sure the wheels are true on the hub. Any spoke/ hub wear?
  5. Long FLD
    Long FLD Road Train Member
    11,378
    45,908
    Mar 4, 2015
    Did you double check that they’re seated correctly on the wheel?
  6. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    Do what @Goodysnap said. This is more common then folks believe. Another trick is to air it up in cage of coarse 20 psi over max to make sure it uniforms itself. Then after a few minutes drop back down to normal. Best if done with valve core out so pressure comes down quickly.
    On the subject of “Blems”. They are cosmetic defects only like lighter then normal or uneven lettering and numbering in the sidewall molding. Sometimes the stamping is blurred. You’d be very hard pressed to find it sometimes. Not a structural defect. Doing that can lead to recalls.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    There should be a molded line all the around the tire less than a 1/4 inch from edge of the rim, take a tire depth gage and go around both sides of the tire line to rim to see if it's on the rim even
  8. Dok2304
    185
    49
    Sep 19, 2013
    They looked , and it’s all good. The weight is there, didn’t fall. The wheel is tight, no play. They used a machine to spin the tire and then they put it against it. When it stopped you could see the area that did contact was sticky and black shiny, and the area that didn’t touch was road dirty. And it’s like big area.
  9. Dok2304
    185
    49
    Sep 19, 2013
    Yes. That guy who did the test looked also, and didn’t see anything wrong. Both tires have area that don’t make contact. Both tires are new, purchase a day apart form same shop. I’ve seen the line, and it’s equal apart from the rim. I go there because those guys are good, they know what they’re doing. They’ve been doing this for 20 years.
    86scotty and Long FLD Thank this.
  10. Dok2304
    185
    49
    Sep 19, 2013
    They used grease when they installed it, and the line is equal apart from the rim. It’s not a bad installation. I may not be an expert, but these people that do alignment and check for play and all that they know. They told me it’s the tire. It’s nothing you can do.
    When I drive 55mph steering wheel wobble left right, and I had no idea. I thought maybe the rim, or the drum. NOPE. It’s the tire.
    Thing is , the shop said they gone have to send the tires back to Michelin, and I have to wait to get my refund. In the mean time I have to buy 2 more tires and wait. This guy said to give only one back, because if Michelin say one is ok, I’ll end up with an extra tire. Go figures…
    On a good side I’m happy that I have found the problem, because it was driving crazy, but…
  11. Dok2304
    185
    49
    Sep 19, 2013
    I think he did that, I didn’t hear any pop noise or anything like that, but he used a lot of grease, I saw that. These people they do that for a long time. These are not kids, like you see sometimes.
    SmallPackage Thanks this.
  12. Dok2304
    185
    49
    Sep 19, 2013
    22.5 low pro.
