Ok so if you have:. * pnematic pump that blows a product out
* Vac pump that sucks product in and blows it out
What is the difference? Would a vac pump not work for both?
Pumps. Pneumatic versus vac pump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Miatiawanna, Feb 25, 2018.
Vacuum pump is for liquid and pneumatic is for dry products like sugar sand or flower
4mer trucker Thanks this.
Think of it like trying to suck or blow a bag of flower through a straw. It won't work until you blow a bunch of air into it, and can suck the air and some flower at the same time. Fluids don't have the same problem.
Blowers usually discharge into the trailer but can be set up, with a self loading trailer, to suck on the filter housing creating a vacuum in the trailer that lets you suck in the product.some have a dedicated hookup while others have to open the air filter canister to hook up the 4' vac line [discharge blower line is 3"]
Wet vacuums are usually hard piped and have a 4-way valve that allows you to switch from suction to discharge by just turning the valve.APD Mechanical and MagnumaMoose Thank this.
