Pulling RV into weigh station.
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Apr 10, 2019.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    I was returning home with wife from Utah back to WA. Once I've crossed WA border there at I82 NB light read "truck must exit to scale" we were driving rental E350 camper truck. What does RV have to do with commercial vehicle weight station?
    No, there were no semi trucks in front or behind us.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    There are sensors in the pavement, but they cannot distinguish between an RV and a commercial vehicle. The sign comes up automatically, but RVs do not need to go through a scale house
  4. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Your RV was heavy enough to register as a potential CMV, so the computer routed you in. Doesn't hurt anything to run through. They will direct you into the bypass lane unless they have a legit reason to stop an RV, which they probably do not.
    86scotty Thanks this.
  5. mitmaks
    2,542
    2,064
    May 16, 2014
    RV is not a commercial vehicle so I didn't stop, #### WA DOT
    adayrider and D.Tibbitt Thank this.
  6. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    That might bite you on the butt in a few states. Especially if the combined weight of RV and anything it is towing is over 26k.
    Some weigh stations in some states do require RVs to pull through, even if they rarely scale them.
  7. jraulpilot1998
    jraulpilot1998 Medium Load Member
    354
    491
    Aug 20, 2014
    All over U.S.A
    Studebaker Hawk Thanks this.
  8. Rickp
    Rickp Heavy Load Member
    765
    1,070
    Apr 14, 2016
    Ward, AR
  9. buzzarddriver
    3,507
    10,015
    Feb 1, 2011
    Dallas, TX
    What about an RV pulling a box trailer, pulling a car hauler, pulling a boat, and pulling a BBQ pit trailer?????
    Trucker61016 and D.Tibbitt Thank this.
  10. dieselpowered
    dieselpowered Heavy Load Member
    832
    742
    May 16, 2016
    Yes, I have seen these campers they pull doubles, triples even some even more then that I am sure the DOT loves those if it's on the highway they can pull you in they can also chase you down if nothing else. and if your hauling a boat across certain states you are subject to being stopped and having them check your boat.
    D.Tibbitt and Farmerbob1 Thank this.
