Puke Tube
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rocky64, Feb 10, 2014.
  1. Rocky64
    Rocky64 Medium Load Member
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    I've driven trucks that have steam or smoke or oil or nothing at all coming from the puke tube. Please speak (write) to the significance of stuff coming out of the puke tube after a hard days running, and to the absence of anything coming from it. My N14, when I picked it up on Sat and drove it 200 miles had nothing coming from the puke tube. My buddy indicated that is a sign of a healthy motor. Your thoughts appreciated....
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Its where compression goes when it leaks past the rings. Little to none is a good thing!
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    this blow by is required on a detroit!
  5. rbrtwbstr
    rbrtwbstr Road Train Member
    3,334
    7,598
    Jul 11, 2012
    in the bush somewhere
    Dang I thought I would be reading about some Chinese driver that put a tube in the cab to puke through while driving...
    Seriously though, if there's nothing coming out of said hose, that's usually a good sign you have a healthy engine
  6. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    41
    Sep 2, 2009
    Nothing coming out is good, however just because an engine has a good bit of blowby don't mean it needs rebuilding,as a lot of people believe, my m11, has a good bit of blowby but don't use any oil
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Blow-by can be from the turbo passing air past the seal on the compressor side, valve seals and guides, the air compressor, cylinder kit problems and a little bit of everything.
    Just a thought!
