Pto shaft will not come off, any tips to get it removed?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mta1972, Feb 5, 2019.
  1. Mta1972
    Mta1972 Bobtail Member
    Pto shaft stuck on pto.. trying to take blower off an old rig and man I have tried everything. I tried tying a come along to the frame and nothing.. any tips
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Use anti-seize when reinstalling it. Are you trying to get if off the splines of the blower input shaft/PTO output shaft or are you trying to separate u-joints?
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    When all else fails, I run for my zip gun on rusted and frozen parts.
    {ogMetatagsModel.referenceTitle} cp
    The vibration loosens the rust bond. Theres one thing for sure.......it will move it, or ruin it coming off. But it will come off.
    Alot of folk die from sticker shock, but IMO worth every penny. There are cheaper alternatives in off brands via Google.
    pushbroom and SAR Thank this.
  5. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Your going to have to heat the part that slides over the shaft with an oxy/acetylene torch.
    Heat it up cherry red and tap it off.
    intrepidor, Dino soar and Humblepie Thank this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    You want a straight pull. Can you hook the come along to a shaft through the yoke? Then the other end to a chain from the bottom of the rear axle. As straight as possible. Pull it tight and use a torch and or air hammer on the yoke.
    Look at that yoke real close for a set screw you over looked. If someone put it on with loc tite or sleeve retainer that stuff starts to come loose at around 350 degrees.
  7. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I would knock out the front u-joint and use either a 2 jaw puller or a small H bar. Run it up as tight as it’ll handle. Then hammer around the yoke to knock it loose. (With a air hammer). I’m not allowed a “Smoke wrench” in the shop. So it would probably help, but it’ll also take out any seals near it.
    BoxCarKidd Thanks this.
  8. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    That tool is a blessing on our farm. They are handy in tough situations.
    Goodysnap Thanks this.
  9. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Oxy-acetylene he really is best for these kinds of situations. Heat expands the metal and it will come off.
    Hulld Thanks this.
  10. raferko
    raferko Bobtail Member
    22
    6
    Oct 23, 2018
    Japan
    I use a slide sledge on all pto yolks
  11. intrepidor
    intrepidor Medium Load Member
    378
    847
    Aug 24, 2017
    Western Iowa
    Whenever we would run into a stubborn problem like this a cry would go up in the shop by my Dad "get the torch".
    Hulld Thanks this.
