PTO on while driving
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by ZooX, May 27, 2020.
  1. ZooX
    ZooX Bobtail Member
    20
    5
    Sep 8, 2019
    Hello truckers,
    I realized PTO was on after driving for an hour. I only know I'm not supposed to do so.
    Any opinion and advice will be appreciated.
  3. AModelCat
    154,238
    Turn it off and keep going.
    austinmike and 650cat425 Thank this.
  4. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    What kind of PTO? If it's like a blower, probably nothing, but a hydraulic, like a dump truck, you could easily fry the pump. Don't you have a light on the dash saying the PTO is engaged? If not, I'd get one.
    austinmike, ZooX and mitrucker Thank this.
  5. ZooX
    ZooX Bobtail Member
    20
    5
    Sep 8, 2019
    Car hauler with a hydraulic pump. I drove for more than an hour. It does have a light on the switch.
    Is there anything I need to check?
  6. 201
    12,044
    24,581
    Apr 16, 2014
    Hydraulic pumps have a certain "working" range. Spinning them too fast usually takes a seal out. If it's not leaking, probably dodged a bullet. Pumps aren't that expensive, but NEXT TIME, WATCH IT!!!:angry5:
    ZooX Thanks this.
  7. justcarhaulin
    justcarhaulin Light Load Member
    152
    237
    Jul 20, 2015
    There is a safety device that you can have installed. Did that when I put pto on my truck. It won't let you release the brakes while the pto is engaged. I think its standard on all stingers if am not wrong. Its a simple device that locks the airlines
    ZooX Thanks this.
  8. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Used to work at a fertilizer company... Most of the trucks had wet kits on them to run the hydraulics. Saw many pumps get burned up because they were drove with pto engaged. Even saw one that had grenaded while going down the road... That one actually took out the transmission as well as it shot shrapnel into the gearbox from the pto itself.
    ZooX Thanks this.
  9. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I fried a pto pump last year from accidentally engaging it when putting seat belt on and snagged the pump lever.
    Burned out in 5 minutes of driving while I was trying to figure out why the truck was feeling like the jakes were activated but not making noise. (No mufflers on this truck)
    The hose was not hooked up to anything so the oil couldn’t flow. So it overheated and burned the pump.
    Now I always have my hose hooked to the return line in case the pump ever gets turned on again but the oil just flows to the tank.
    Reason for edit: Spelling
    Dino soar, ZooX and Doealex Thank this.
  10. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    It's really easy to wire a warning light into the PTO system. A big red light on the dash, especially if it blinks continuously while the pump is engaged, is a lot cheaper than a new pump.
    Shawn2130, ZooX and Doealex Thank this.
  11. ZooX
    ZooX Bobtail Member
    20
    5
    Sep 8, 2019
    Would be great if you could tell me how. Hope I can do it myself.
