PTO MAINTAINANCE AND COLD WEATHER
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by justcarhaulin, Jan 17, 2022.
  1. justcarhaulin
    justcarhaulin Light Load Member
    152
    237
    Jul 20, 2015
    Hallo carhaulers. Am having some hydraulic issues with my 2016 cotrell stinger. This happens whenever the temps are below freezing. Here are the two issues
    1. Pto engages but the cylinders won't move either up or down.
    2. Frozen cylinders. Not all of them.
    3. Pto engages and the cylinders move only on the headrack but not on the trailer.
    I've been using the electric back up to get the hydro fluid warmed up. This helps get things going after a while.
    Is there something or maintance I can do to help with these issues? Thank you and stay safe out there
  3. Banker
    Banker Road Train Member
    4,017
    11,409
    Aug 19, 2012
    First thing I would do is replace both hydraulic filters.
    I change them every year as condensation gets in the filters and when it is bad the cylinders will act like you are experiencing. While you are under there doing the hydraulic filters replace your air dryer filter. (Drain all air first). I do all 3 filters my last service before cold weather hits. I also gradually switched over to the thinner 32 Hydraulic fluid from the 46 that it came from Cottrell with. You can buy it in a 5 gallon pail and mix it with what you currently have in it.
  4. Banker
    4,017
    11,409
    Aug 19, 2012
    Side note that may not effect you but others it may. If you have an empty deck that struggles to come down you likely have rusted metal clogged up inside the post. My high rail once did this on the back top deck. It had holes at the bottom of the post that were designed to wash out the rust. Spray PB Blaster form the top of the post to the bottom and let it sit for a while. Then hose the rust/metal out from the top down and make sure the water is flowing freely.
  5. Hammer166
    7,350
    26,445
    Aug 18, 2007
    ~8600+' and loving it!
    In addition to what @Banker recommended, you might consider changing out the hydraulic fluid. It sounds like the entire system may be carrying water.
  6. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    In the bottom of the outside upright tube, drill holes so the water can drain out. Grind down and slip plate the inner tube. Occasionally spray the inner tube with antifreeze so the water will not freeze.
  7. justcarhaulin
    152
    237
    Jul 20, 2015
    Thank you all for the advice. I appreciate it. I've learned alot from this site. I think I'd better pay more attention maintance wise as my truck gets older.
    Tall Mike and BigBob410 Thank this.
