How does one engage the pto, while on the move, in a mack dump truck or tractor with side dump? Iv seen guys flip the tube over or put the box in the air while on the move never stopping once. I asked one of the guys i work with and he said you just push the clutch and flip the pto on. I tried pushing the clutch halfway in to turn it on but it just grinded so i shut the pto off. My next thought was you have to push the clutch all the way to the floor but that seems like it would destroy the clutch brake so i havent tryd. I know the mack vision i drive now can do it as iv seen someone else drive it with the same trailer and tilt it on the go. So how is this done?? Thanks in advance
PTO engagement on the move
Discussion in 'Questions From New Drivers' started by Big.D, Jan 16, 2017.
That's the only way I know to do it is flip the button while you are holding clutch in or flip the button and let the pto grind till it engages
Hmmm interesting.... Just seems that would be bad on pump and transmission
They obviously don't own the equipment, because the time they are saving by not stopping to properly engage the PTO isn't worth the potential damage caused by engaging it "on the fly".
The only way I can figure is they knock it out of gear, use the clutch brake to stop the input shaft, engage the PTO, release the clutch to get the gears spinning again and then get the truck back into gear. Great way to prematurely wear out the clutch brake. Have you ever seen a clutch brake? The friction layer isn't very thick...doesn't take much to use them up.OLDSKOOLERnWV Thanks this. -
Thats what my thinking was. I didnt know if there was a little trick i didnt no about or what. Thanks for info.
If I caught you doing that in my truck, you'd be out of a job before the load hit the ground. Getting in a hurry at a job site will eventually result in injury and tore up equipment.
markk, Big Don, Bean Jr. and 1 other person Thank this. -
PTO, power take off, drains power from the engine, transmission and drive shaft. Raises a dump bed or something.
Don't pop that PTO while moving.
With that said...
When I was running blacktop and stone with the Mack 500 super dump, once in a great while there is a chance to "Spread" the rock down 200 feet of bare dirt with a raising bed while moving. Put her into 2nd, clutch in, service brake on, hold then trip the PTO and start raising the bed, take off and move allowing the rock to spread.
Make #### sure your gate is chained. A couple links is enough to make that gate back there on the end of your dump bed open just enough to spread rock nicely.
Have a spool of spare TV cable ready to re-install if you snap it while spreading. Once the bed reaches it's max, that #### PTO needs to be taken off. And you get that rig stopped. It's a bit of a dance but saves a great deal of labor. NEver come out of 2nd all the way down until bed is empty.Big Don Thanks this. -
Well those guys are what are known as hacks. The ones who destroy equipment and make us mechanics want to throttle them for being so ####ing stupid!
Stop the truck, stop the transmission gears, engage the PTO.OLDSKOOLERnWV, MACK E-6, Bean Jr. and 3 others Thank this. -
They way they do it is the same way you do it stopped. Put in the clutch in all the way (not half way) with the truck in gear. When they let the clutch out the PTO engages also. I agree that this sounds damaging. I have never done this.
I have driven at low speed with the PTO engaged to help the flow of gyp rock out of bulk tankers when dumping on the ground. I was always stopped when the PTO was engaged though because I had to get out of the truck to open the trailer bottoms anyway. That flow of air helps keep the rocks from binding.
Also for the guys that dump gyp with the butterfly valves, if you don't already know, if you didn't crack the bottoms a little before loading and the valve doesn't want to open, run up some air pressure in the tank with bottom air and that will help loosen that valve. Be ready for a slight blast of dust as the bottom finally cracks open.
On a side note. Funniest thing I ever saw. Even though we all knew the company was talking about trailer bottoms, they put up notices all over the place that said "If your bottoms are leaking, let the shop know immediately".
I told the dispatcher if my bottom is leaking, I'll call the doctor. He wasn't amused.Big Don Thanks this. -
