prostar shaking when braking
Discussion in 'International Forum' started by barnshark, Feb 19, 2014.
  1. barnshark
    barnshark Bobtail Member
    15
    Jan 5, 2014
    Its crazy. It ONLY does it when slowing down, and only between 40-55mph from what I can tell. You can feel it in the wheel almost like its a bad rotor, but the truck doesn't have rotors, it's a 2010 model....any suggestions????
  3. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    I would say its a warped drum. Out of round
    barnshark Thanks this.
  4. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    DING DING DING I'm almost sure this is what you have, It was really hot sometime and the brakes were set and it warped it because they didn't drive a little ways so that this wouldn't happen, If you know your brakes are hot don't just stop and set them and then go home for the night, If they are hot cool them off by driving around the yard a few minutes and then park it and sit without the brakes on, unless your yard is the side of a mountain, but you know what I mean. I'm almost sure it is warped.
  5. FozzyNOK
    FozzyNOK Road Train Member
    2,452
    3,774
    Jul 18, 2007
    Oklahomistan
    When doesn't it shake?
  6. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    Does "slowing down" mean "braking"? Any wheels been off recently?
  7. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    My 2010 Prostar had a badly out of round lh drum that would shake accelerating and braking. Jack up the front end and see which tire won't spin freely. If both spin very lightly apply brakes and see which one can't be turned. BTW the front drives are the only brakes that set when you set the parking brake.
    Frank
  8. FLATBED
    FLATBED Road Train Member
    Bad wheel bearing will give you a shimmy as well when slowing down
  9. barnshark
    15
    Jan 5, 2014
    Thanks guys. Ill take it in to a shop. It does it at 40-55mph when the brakes are applied only.nso kust be brake related. Figured someone would have a good starting point so I know if shoo is tryna throw a curve ball
  10. 2014Instar
    2014Instar Bobtail Member
    Did you ever figure out what it was
  11. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Out of round drums is what causes this.
