just got assigned the truck. headlights suck, all the light is 2-3 feet in front of the truck, aimed too far down, not where i need it. how do you adjust the aim of the head lights?
prostar headlights
Discussion in 'International Forum' started by Txdriver77, Feb 7, 2018.
Do a little at a time and check the progress frequently. -
Checking it out in the daylight? You will not be able to see it hardly.
There should be a circular bracket the bulb goes in. Lots of time when installing, you go over or under. I know it's good if installed with the hood open. Look at the ground and you should see a straight line of light coming from the bulb.
