Prostar check engine light will not clear
Discussion in 'International Forum' started by habfleet, Aug 17, 2015.
  1. Triton
    Triton Bobtail Member
    good morning! I have a fault code SPN 524285 FMI: 14 (2013 International prostar) Maxx Force
    Truck is running fine, no loss of power, no smoke and no leaks. What gives?
    Thank you!
  2. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    SART module. It just records time when a fault happens because the engines don't have internal clocks. "Stand alone real-time" module. It is actually battery powered and likely has a dead battery. When these go bad the only code that leads to trouble is the ambient air temp does not agree with others codes that can lead to a failed regen. It takes a unique combination of circumstances to induce this code and another round of low probability conditions for the regen to not happen, so this rarely causes a failed regen, but it is still possible.
    PowerAll and QUALITYTRUCK Thank this.
  3. Precision_Logistics
    Precision_Logistics Bobtail Member
    4
    HeavyD, i have spn 84 fmi 5, spn 5246 fmi 15, spn 3984 fmi 2, spn 84 fmi 19, spn 84 fmi 15. And def tank marks empty. 2015 Prostar n13
  4. Precision_Logistics
    4
    Also, can alternator wire connections be causing this? We had the alternator replaced
  5. Heavyd
    7,804
    6,253
    Feb 4, 2009
    84-5 not on my list of engine codes, might be from something else
    5246-15 SCR tampering inducement level 1, you have been ignoring a DEF related fault warning light.
    3984-2 not on my list of engine codes, might be from something else
    The only 84 series of codes is 84-2 for vehicle speed anti tampering.
    What are you using to read codes?
  6. Ashpault runner
    Ashpault runner Bobtail Member
    2006 international 7700 , yellow engine light came on won't go off , super lack of power, checked all fluids, and batterys ,can someone please help me , thanks
  7. bigwalt333
    bigwalt333 Bobtail Member
    @Heavyd
    2011 international prostar max force
    Yellow engine light
    Code:
    Sw rev 6.1 hw rev c1
    Any ideas ??
  8. Heavyd
    7,804
    6,253
    Feb 4, 2009
    Those numbers mean nothing to me. Where are you getting those numbers from? Those are not fault codes, but display software from some sort of display screen. Software revision 6.1, hardware revision 1
