What is the pros and cons of a flatbed and a step deck? I was messing around with the load boards and noticed that with the flatbed and step deck loads they are no more than 100 miles. Talk about a lot of short runs! That is only in my state of Illinois!
Pros and cons of flatbed versus step deck
Discussion in 'Ask An Owner Operator' started by Double L, Oct 21, 2008.
Page 1 of 7
tryin to stay instate is gonna be hard...theres alot of steel that leaves il, not much that stays in it
flat is more widely accepted, and can load just about anywhere...con..cant due a whole lot of machinery, and it doesn't take much to need a permit for height
step....a specialized trailer and should pay more than a flat, though it often wont...can haul any flat load, if the shipper will allow it (some wont), more versatile, can haul taller without permits
con....you will sit longer in some areas, and it costs moreNative Dancer Thanks this. -
Thanks Bronc, I think I'd have better luck with dry vans freight wise.
dry vans are cheap!!!
get a flat, learn to PROPERLY secure loads, run yer hiney off..smiling as you enter the bank -
I seen some instate flatbed runs that look good but they are mostly up north though and I live near East St. Louis!
The way rates have been dropping i dont think theres any difference in money pulling a flat or van.
Good luck strapping in -10 or tarping on a 100*F day.
No pun intended to you stinky flatbedders -
Actually I found a flatbed load from Streator, IL to Calumet City, IL paying $275 for 92 miles paying $2.98!
Heard that Pete of your's wouldn't pull a sick wh ore off a piss pot.
James j Thanks this.
Page 1 of 7
