Proper Hub Oil Level
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 98T800NY, Mar 1, 2024.
  1. 98T800NY
    98T800NY Bobtail Member
    12
    7
    Feb 14, 2024
    Hey guys I'm back with another Newbie question haha.
    I was looking at my trailer and to me it looks like at least 2 of the 4 hubs are low on oil. I've included pictures of each hub in the post.
    I'm seeing a lot of conflicting information on the internet about what it should be filled to. Some say the fill line, others say fill it to the point where if you stick your finger in, your finger tip gets wet. Lastly some say fill it right up the the plug hole like you would if you were filling a differential.
    The trailer was an auction buy so I don't know the history. I don't see any seals leaking and inside the wheels by the drums look dry, no signs of oil leaks. I have a old 1983 Penski Dry Bulk trailer.
    Thanks for any insight, this forum has been great.
  3. Coolbreezin
    Coolbreezin Medium Load Member
    392
    393
    Jun 11, 2016
    Florida
    As an O/O with a 1991 truck with the same hubs, Id flush extremely well and fill it to the recommended level on the hub cover.
    Vampire, gentleroger and 98T800NY Thank this.
  4. skallagrime
    skallagrime Road Train Member
    3,836
    9,877
    Apr 10, 2012
    Indiana
    As a preventatitve, coolbreezin is correct, but the only one im extremely leery of is hub 3, the rest look like oil, 3 looks like dirt mixed with water
  5. 98T800NY
    12
    7
    Feb 14, 2024
    When filling to to "full" line would you consider it properly filled in Hub 3 or is Hub 1 at a better full level?
    Hub 3 almost looks like it is above the full line and overfilled.
    I know the sight glasses are hard to see, sorry about that.
  6. skallagrime
    3,836
    9,877
    Apr 10, 2012
    Indiana
    Between add and full is the correct level, obviously closer to full than the add line.
    3 is definitely overfull, but see above post
  7. 98T800NY
    12
    7
    Feb 14, 2024
    I just went out and dipped my finger in hub 3. It feels like good gear oil. I is a lot cleaner/newer looking gear oil than is in any of my oil hubs. Also is my newest looking sight glass so it makes me think the previous owner may have changed that one out not long ago or done some service and accidentally over filled it. Should I run it at that level or try to bring it down a little? A flush and fill would allow me to adjust the level.......
  8. skallagrime
    3,836
    9,877
    Apr 10, 2012
    Indiana
    Fair enough
    Reduce to correct level should be good enough, there SHOULD be an allen key style plug in the hub itself if you can break that loose to drain, should be pretty easy, IF you can break it loose that is...
  9. Arctic_fox
    3,861
    19,402
    Sep 16, 2016
    Id flush fill all of them anyway. Its not that espensive, lets you get new gaskets on, and ensures you have fresh gear oil in there. Also will show if there is any metal or anything else of concern in there or any damage you may not be able to see with the hub on. Also lets you set a maintaince record for that item.
    gentleroger Thanks this.
  10. skallagrime
    3,836
    9,877
    Apr 10, 2012
    Indiana
    For the record, this is still the smart thing to do
    98T800NY Thanks this.
  11. FLHT
    FLHT Road Train Member
    1,329
    2,261
    Aug 2, 2014
    The clear plastic lens are cheap and easy to replace.
    I would also put new plugs in Cheap too.
    The plugs have a small hole in center to let pressure from heat out.
    98T800NY, Vampire and gentleroger Thank this.
