Just replaced the cecu on a 2013 389 Pete . Looks as if it needs to be programmed as none of the gauge or dash works at all.. Which software is needed to program this?
Taking it to dealer is not necessarily an option as the engine is missing some parts...unless I can just take them the cecu unit and have it programmed that way?
Any help is appreciated
Programing CECU on 389 pete
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by D.Tibbitt, May 8, 2023.
DeereRunner97, God prefers Diesels and Rugerfan Thank this.
No way to remotely program. You need ESA factory tool to program CECU.
I know…..just full of good news.Rideandrepair, DeereRunner97 and D.Tibbitt Thank this. -
Rideandrepair and DeereRunner97 Thank this.
You can order direct thru any dealer and is a subscription and will be a pain to get ahold of you are correct.
What’s broken? And why must you replace it?Rideandrepair, DeereRunner97 and D.Tibbitt Thank this. -
anything else i should be looking at or diagnose first ?Rideandrepair and DeereRunner97 Thank this. -
Yea, voltage. If your alternator is overcharging the controller will shutdown to protect itself. Just a first thought.
To be honest, the program will cause more frustration than it’s worth as the update and flashing process is confusing and complicated even to those that are trained.
I would weasel in a dealer and hope they can get it sorted on the chassis side without monkeying with the engine.Rideandrepair, DeereRunner97 and D.Tibbitt Thank this. -
Rideandrepair, DeereRunner97 and Goodysnap Thank this.
It will be high. 15-16vdc and up.
If I can assist with any info please PM your vin with direct email and I will send you some stuff tomorrow.Rideandrepair, DeereRunner97 and D.Tibbitt Thank this. -
