Problems with an International LT 2019 model
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Aerosol, Dec 28, 2020.
  1. Aerosol
    Aerosol Bobtail Member
    7
    Mar 17, 2019
    I'm not sure if this is the correct forum for this. So, sorry if this is in the wrong place.
    For some reason in this new international that I have, both of my doors unlock whenever I pull my air brakes. Is there a way to disable this? I've been in a hurry to run into the store and didn't lock my passenger side door.
    Also how the hell does the sleeper Auto climate function? Every time I tried to set it within a few minutes it's full blasting heat when I'm trying to get it to cool down in the truck. Other times it gets really cold. I have no idea why it does this or how it functions. Every time I try to manually adjust it from the bunk thermostat, it immediately goes right back to what it was set at. the only way to get it to cool down or heat up is to hold the button down so it's unable to go all the way back up to full heat or full cold. If anybody can shed some light on this and tell me how dumb I'm being, I would really appreciate it.
    Thanks, drivers!
  3. Lostkeys
    Lostkeys Heavy Load Member
    903
    6,243
    Jan 8, 2011
    Archbold,OH
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Did you read the manual?
    Flint1 Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    The door locking can be programmed out, but you need to see someone with Diamond Logic Builder software for that. As a tech, I don't get into the sleep hvac function too often, so maybe someone here can help better.
    Flint1 Thanks this.
  6. Team7
    Team7 Bobtail Member
    11
    Feb 19, 2017
    @Heavyd you know your stuff. I've followed your advice on the international wiring in the past and it worked. Just saying thank you
    Heavyd Thanks this.
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Thank you for that. I appreciate the kind words!
