Problems filling DEF tank at pump.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bob9814992, Dec 2, 2014.
  1. Bob9814992
    Bob9814992 Bobtail Member
    41
    15
    Feb 18, 2012
    Indiana
    I have a 2014 Volvo with a Cummins 500 with the SCRs DEF system. I am having problems filling the DEF tank. The pump keeps shutting off making it near impossible to fill the tank. I have replaced the filler tube screen and it still causes problems. I was also told to wipe off the nozzle before trying to pump. Is any one else having the same problems or have any suggestions.
  3. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    yes same problem
    I drive a multitude of trucks weekly and have experienced the same thing with all of them but the Volvo seems the most inclined..
    if you have a good idea that it needs what the gauge says it needs then you have no choice but to be persistant and go SLOW..
    option is to fill a gallon jug and get a funnel and pour it into tank after filling jug..
    maybe put the funnel into tank and pump into funnel?
  4. blairandgretchen
    13,212
    70,210
    Dec 9, 2011
    South west Missouri
    Make sure the nozzle is seated snugly in the filler tube - and go slow, or kink the fuel line to restrict flow - the pumps are a PITA at best to operate.
  5. daywalker24
    daywalker24 Light Load Member
    There is a magnet in the receiver hole (usually blue in color) get a circular magnet which will fit over nozzle and it will activate the metal ball in the nozzle to stay open (also why the nozzle is aluminum ) should fix it.
    mhyn and teqntexas Thank this.
  6. teqntexas
    teqntexas Medium Load Member
    689
    547
    Jan 25, 2012
    Ft. Worth Tx.
    this sounds crazy BUT i had the same problem but in a freightshaker and this was the answer.
  7. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    I've noticed the same problem some pumps are worse than others. FlyingJ in Rawlins Wy furthest pump to the east will fill it till it starts runnin on the ground. Haven't found a pump at a Loves that cooperates. Worst one I've found was the one @T/A in Rawlins.
  8. daywalker24
    The problem is the strength of the magnet on your tank and the build up of gunk on the inside of the nozzle and ball. Love's at the 211 on the 35 in Oklahoma has a one of the inserts from a tank that holds the magnet because their pumps are real bad. Just sometime walk into the store and ask the clerk if they have a magnet for the Def pump you might be surprised how many actually have one.
    dirthaller Thanks this.
  9. Bob9814992
    41
    15
    Feb 18, 2012
    Indiana
    That makes sense and would be an easy fix. Where can I get a circular magnet of that size?
  10. daywalker24
    Hardware store or grainger, or truck salvage should have the inserts,or just ask to yank one out of junk tank.
  11. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    I have had success by pulling the hose out far enough to place over shoulder when filling
    Works well 8 out 10
