Problem with Cab dome light
Discussion in 'International Forum' started by texasmorrell, Mar 28, 2015.
  1. texasmorrell
    texasmorrell Medium Load Member
    597
    625
    May 3, 2012
    Lone Star State
    The dome light in my truck only works about half the time. It's controlled by a three position switch on the dash. The three positions are cab dome, door, off. When the switch is in the door position the light is supposed to turn on when the door is open. The courtesy light on the bottom of the door is also supposed to turn on. These lights very rarely turn on when I open the door. But they will on rare occasion. The light is supposed to turn on whenever the switch is in the on position. This function works about 50% of the time. I am wondering if anyone has ran into this problem before and what the fix was. I'm pretty sure the body controller has no control over this function. So the problem should be in the switch itself on the dash. For example, I just turned the light on by flipping the switch to the cab dome position. I then immediately flipped it back to the off position and the light went out. I then immediately flipped the switch back to the cab dome position but the light does not come back on again. Please chime in if this sounds familiar to you. I have an 09 Prostar by the way.
  3. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Tbh, it could be a short in the assembly of the light or It could be the switch is wore out. I had to replace my door sensors once as when it was in the door position it would not bring the light on when the door open. Bright side is these switchs are somewhat cheap, between 10 to 35$ depending, for the factory version you can pick one up at international if need be.
  4. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Make sure the dome light switch in the actual dome light itself is not stuck. Wiggle the door switches with the doors open, pull out on the switch to see if there is a bad contact when the door is open.
