hello i got a problem with my ebs system the STOP light is burning.
this are the fault codes:
MID 136 SID 9 FMI9
MID136 PSID30 FMI7
MID136 SID66 FMI9
hope you can help me.
truck is with a i shift transmission.
regards Ronald. (from the netherlands)
problem ebs/abs volvo fh12 460hp 2002
Discussion in 'Volvo Forum' started by giesingnl, Oct 17, 2013.
Ronald look up the codes online, just Google Volvo ECM Codes or computer codes!
i looked up at google.. but i cant find the right answer for my problems..
hope somebody can help me here! -
oke ill wait for him.. hope he can help me!
sid 9 - left rear modulator valve is bad
PSID 30 - low pressure in air system
SID 66 - TCM problems -
oke thank you
and the left rear modulator is an electric problem or it is the valve? -
usually internal problem, becouse rear and left modulators are in one box
try to reset code. to do it, build pressure till compressor kiks off, press brake pedal and gently release it twice ore more, do test drive and try to reset code. as default dashboard password is 0000, 1111, 1234 ore 4567 ore 5678 -
[TABLE="class: table"]
[TR]
[TD="class: rowcol1"]SID 9[/TD]
[TD="class: rowcol1"]ABS control solenoid valve, rear left[/TD]
[TD="class: rowcol1"]Modulatorvalve L1R[/TD]
[/TR]
[/TABLE] -
MID136 PSID30 FMI7
Incorrect response from the mechanical system.
Conditions for fault code:
- If the pressure in the parking brake circuit tank falls below 5.4 bars, this is indicated by a fault code.
- If the pressure in a circuit tank, front or rear, falls below 5.4 bars, this is indicated by a fault code.
- Low pressure in the air system.
- Faulty switch (2075).
- Faulty instrument.
