My truck is choping up tires again at only 40,000 miles i did a alignment and centramatics with bridgestone r260 i also did new shocks and the front end is good the alignment shop i use said its in spec
do yall think a pro-trac alignment would be the way to go? and whats the cost?
pro-trac alignment
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BAYOU, Mar 5, 2011.
Page 1 of 4
Bill -
Pro Trac is a system developed by Mike Beckitt (spelling?) out of Altoona, Iowa. Various members of my family and me have been using a shop out of Des Moines, Allied Oil and Supply, for alignments for a few decades now. Ask in there about the Pro Trac system and you will get a chuckle. I was just in the other day for a steer tire and alignment, and Todd, who does there alignment work, just had to redo a truck that had gotten the Pro Trac alignment. Todd is having to redo a lot of trucks that have gotten Pro Trac done. He was telling me of one truck he did a couple of days prior to mine, that was from the SF Bay area that had the Pro Trac done a couple of times and still having problems. Todd corrected problems and owner is doing fine with it now. Todd ALWAYS does all axles when he does alignments, not just the steer axle.
Got into a squabble over this with Beckitt himself, and Kevin Rutherford from the "trucking business and beyond" show on XM. I told them both to go ahead and call Todd at Allied in Des Moines and get him on the show and prove him wrong. I told Todd and have asked several times since if they tried to contact him. Not in almost a year since the squabble began. Todd is also an instructor at a local Tech school, training people on truck suspensions and alignment.
Guess I am just biased, but only because I have gotten excellent alignments from Todd over the years, at the same or lower cost than anyone else. Todd took the time one day with me to actually go into detail and show the problems that he has had with the Pro Trac system. If you think I am full of it, direct all your questions to Todd at Allied, 515-262-9381. I am not the expert, he is. The entire shop is contientious about the work they do. Even the tire guys check things out when they change a tire, and if they find something suspicious, they refer to Todd who then does a thorough check of the suspension, bearings, etc and then brings it up to the owner on what they need to do to correct the problem. They have saved me considerable bigger problems and downtime by catching a bearing ready to go out and other things.
From everything I have learned, Mike Beckitt is a very knowledgable guy, but his Pro Trac system is highly dependent on the person using it. Results are all over the place. Alignments are as much an art as they are a science. To get the best, you have to rely on the person as much as the system. So many people doing alignments should not be doing them.
Your call. Do what you feel compelled to do.Last edited: Mar 6, 2011
rabbiporkchop and sshewins Thank this. -
Cowpie im about 100 miles from houston,tx and have had my truck at 2 different shops back to back i was not happy with the first shop the truck was pulling to the right bad the 2nd shop put a 6 degree shim on the pass side that shop is the one that talk me into going with new tires and centramatics the guy said i would be good for 100,000 miles or more but like i said im at 40,000 and the truck is all over the place and i know its not going to get anybetter
The pro-trac shop is in dalles 300 miles from me but if they can fix this i dont care
Kevin Rutherford had a guest from md alignment few weeks ago and he made perfect sense most shops try to make the the front end go straight the guy was saying its like a boat if the motor is off on oneside your steering wheel will be off yes you can make the boat go straight but if the motor was in the middle it would go faster and not have to work as hard -
Sounds to me like posiably a bad king-pin or even a steering shaft u-joint...... my u-joint was worn and made the steering wheel float a bit and started causing my steers to cup. I replaced the u-joint and had the front-end rebuilt too with hubs, berrings, king-pins, brakes, drums ect..... i now have 225K on my Goodyear steers with 8/32's left, even wear!
sshewins Thanks this.
I just had new kingpins installed and then a 3axle pro-trac alignment by my KW local dealer. The truck is perfect now. It doesn't drift or wander and they even got the steer-ahead dead on. $189 was the price, plus a few dollars for shims on the drives. They were 1/16" off.
My dealer also noted that when the original owner upgraded to the AG400 they put the sway link bushings on the wrong side. That restricted
driveline movement and unfortunately it took it out on the input shaft...
As stated earlier, I think it is highly dependent on the person doing the alignment. I had to wait about a month for the specific guy I wanted to free up to do my work.sshewins Thanks this. -
The $189 figure you use--thats just for the alignment right? not everything you mentioned having done?
$189 CHASSIS ALIGNMENT - SPECIAL
+$53.99 additional labor
+$42.08 additional parts
+$197.32 Labor to correct AG400 sway bar end bolts
..I had many things done on the last visit. The bill was rather high...sshewins Thanks this. -
Ruthless Thanks this.
Page 1 of 4
