Printing on the Road
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Criminey Jade, Apr 26, 2014.
  1. Criminey Jade
    Criminey Jade Road Train Member
    1,609
    1,802
    Aug 16, 2013
    Not Colorado Anymore
    I am running into an unexpected difficulty being out. Printing things! Our company sends updated documents and permit info for trucks electronically. This forces me to search for places to download and print things which aren't always convenient to a truck stop. Sometimes, the shopping center isn't big enough to get the truck in and out of. I am beginning to hate how often I need access to a printer. I need to buy one.
    Which printers travel the best in a bouncy truck and stay reliable?
  3. drvrtech77
    drvrtech77 Road Train Member
    13,645
    132,879
    Mar 20, 2010
    I have an epson wf-2540 wireless printer that connects on my hotspot on my iPhone...works wonders...makes life easy out here..
    tacomaruss and GITRDUN45 Thank this.
  4. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    I got a 2512 HP Deskjet and it has held up great for the last six month. It has not fallen out of the cabinet yet, but the frost heaves on the Alaska Highway are brutal. If you work of a cell phone get a printer that has blue tooth. That will save you messing with USB cords. I bought mine at Walmart and they had a two year free replacement plan for $5.00 that I got with it. I figured that was not much money for the warranty and Walmart is usually easy to find and has parking. Ink is not to expensive for the refill. The black is about $15.00 and had one refilled at Costco for about $10.00. I use mine almost everyday and would not want to be without one these days.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Epson workforce-630. Have one in the truck and one at home, exact same. Easy to carry extra ink. Connects to laptop via USB. Wifi (usa) through verizon data/hotspot. Canada internet - have a Telus internet card. Saves tons of money not paying for faxes. Reduces headaches considerably also. It also scans documents.
    GITRDUN45 and vikingswen Thank this.
  6. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    where did you get a bluetooth. cuz they don't seem to be around these parts. and what i can find on the net. is EXPENSIVE.
  7. vikingswen
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    I don't have a blue tooth set up. I plug my cheap printer into my lap top. Just heard somebody mention Bluetooth, but maybe they misspoke and meant wireless. I am severely challenged when it comes to stuff like that. I go by the kiss principle and usually still struggle or figure out a way to screw it up. I just got an Iphone and people close to me are rolling on the floor laughing while watching me trying to make it work. Not feeling your fingertips and touch screens are a not a good combination, but provide a great source of entertainment for others watching me.
  8. MsJamie
    MsJamie Road Train Member
    For any current inkjet printer, the vibration shouldn't be an issue. As long as you don't let the printer go bouncing around on the floor, it should be fine.
    The big killer is dust. Every once in a while, blow the dust out of the printer, and then clean the feed rollers. Do this once a month or so, and it'll last.
    While I'm not a fan of extended warranties/service policies, I do make an exception for things going into a truck. $5 is cheap piece of mind... provided you don't lose the paperwork! :)
    vikingswen Thanks this.
  9. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    I've got an Epson XP-300 multi (print/scan) that works well. Ink is more expensive than I like, and I print a lot, but for on the road it isn't bad (and Walmarts tend to stock the ink for it). Been looking at one of the compact laser multi's but my small 400W inverter might not be able to handle it.
  10. MsJamie
    A 400W inverter isn't going to handle a laser printer. You're going to need a 2000W+ true sine wave inverter to even hope to run a laser.
    The problem is that a laser printer needs a huge surge of power when it starts to print. The main culprit is the heating elements in the fuser section. Most laser printers will blink the lights in the room when they start up.
    X-Country Thanks this.
  11. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    I got a Canon MG3200 at a WalMart. Don't remember the price, but it was not expensive. It also works as a scanner, so it has saved me a ton of money by scanning and emailing what I had to fax in the past. It has wireless connectivity, but I don't use it. You can also get oversize capacity ink cartridges for it. I bought a plastic drawer type box for it, lined it with some foam padding, and it has not given me any trouble in the past year or so that I have had it, and used at least weekly.
