priming fuel through the Compucheck Test Port?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mixingconcrete, Oct 8, 2021.
  1. mixingconcrete
    mixingconcrete Light Load Member
    99
    40
    Apr 14, 2019
    hello, we have a cummins ism and it doesnt have a hand pump so its always hard priming them after doing major engine work. I found 2 Compucheck Test Ports on the fuel pump and was wondering if i can prime the engine using a vacuum pump on the Compucheck Test Port. Has anybody ever tried that? or what is the best way to prime the cummins ism engines?
  3. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    On trucks without a primer pump I have an air fitting that I put in place of the fuel tank vent and use a regulator to put 5-10 psi to the fuel tank.
    w9l, spindrift, MAMservices and 2 others Thank this.
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    I've used the compucheck fitting on the fuel pump inlet elbow to prime the system. Works fine with a vacuum pump.
  5. mixingconcrete
    99
    40
    Apr 14, 2019
    we tried that couple times but doesnt always work for us
  6. mixingconcrete
    99
    40
    Apr 14, 2019
    How well does it work with a vacuum pump? do you have to vacuum it for a while? we tried on one of our trucks but it still wouldnt start.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    How often are you doing major engine work on this engine that this is a problem?
  8. pup
    252
    256
    Dec 3, 2011
    n.h.
    I use mighty vac hand tool with the small reservoir cup. Fill the cup a few times until the air in the fuel is gone. Works great
  9. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    I have used the air pressure regulated to 5psi or so many times. I have even used one of those blow guns tapped into air at driver's seat. If you have vents in each tank and unvented caps pinch the little vent hoses shut with Vicegrips, leave one cap on wrap blow gun with a rag and stick it in place of the other fuel cap. If you have an electric lift pump turn key on put air to tank and listen for lift pump to start bogging down as it picks up the fuel. When the pump sounds steady release pressure and remove pliers on vents. Good to go, hopefully. I have removed the compucheck fitting in leu of a bleed screw when I couldn't depress it and do the other stuff at the same time. That was with no electric lift pump.
