I have a 2010 PROSTAR w/ ISX Cummings engine. Recently had the air comp replace a year ago and recently, the main air line off the comp replaced. Now my primary and secondary air pressure gauges are bouncing around. I have air pressure the governor kicks in and seems to be working fine, yet the gauges , not at the same time will go up in pressure to alarm state then back to normal or swing the opposite way....I need help?
Primary & Secondary air gauge issues, bouncing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by REELLO, Jul 16, 2017.
It sounds like you have electric air pressure gauges that are failing or their sending unit's are failing; Manual gauges don't jump around.
Air compressors do not cause wild air pressure swings. You still have gauge issues. Both primary and secondary gauges are feed data from the body controller which reads from pressure sensors. If you have a brake application pressure gauge, see if it is also acting weird as all three sensors share the same 5 volt reference from the body controller. If not, I would say you still have a wiring or body controller issue.
RET423 Thanks this. -
I’m having the same issue did you ever figure out the issue????
My primary air gauge drops down when I accelerate... The more when I accelerate longer to the point when it drops from 120 to 90, both air gauges will point to 6o clock and buzzer beeps... It'll stop about 5 to 10 seconds of me coasting... Air app gauge acts like the boost gauge. (Needle moves exactly like the boost gauge needle)... Pretty sure I have BCM problem...
Those legendary Cummings engines do not seem to build air when they should.
