primary and secondary air gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gakid, Mar 2, 2012.
  1. gakid
    gakid Bobtail Member
    6
    I have a 99 freightliner Classic The primary side on the air gauge is on 0 secondary is on 125. I reversed the lines in the gauge works just the opposite, I have replaced the brake proportioning valve on firewall and still primary on 0 secondary 125, there is no blockage from fiewall to gauge, what could cause this?
  3. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Bad check valve on tank?
  4. gakid
    6
    No air going to primary tank from the firewall
  5. gakid
    6
    E s I apply air too large green line from firewall To the primary tank The gage on the dash will show pressure
  6. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    The check valve on your air tank is bad when the primary tank gets to a certain psi then the secondary tank opens and starts filling the secondary tanks the check valve only let's air in but not back out the same line check the valve at the main feed line to the tank air goes to the wet tank then to the primary tank and finally to the secondary tank
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    first of all identify air drier and tank filling valves
    You may have valves on every tank ore four way valve like on european trucks.
    As I remember valves are usually located in front bumper eream but if yoy got version with four way valve it is under driver's step
  8. gakid
    6
    If I empty the air supply and crank up the truck The secondary tanks will feel and primary receives no air
  9. gakid
    6
    Do you know the air flow diagram From the compressor
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really there are two classical systems only. Generally there are four tanks.
    1. Rear brakes
    2. front brakes
    3. park brake valve and trailer air supply + TCM
    4. Auxially tank (cab suspention, tranny air servos (range, splitter ore auto), clutch servo (if used)
    and some trucktors got additional air suspention tank.
    Old system has valve for every tank, newer - four way valve
    Ok some good handbooks
    http://www.wsafc.org/WSFMA/Shared Documents1/Bendix Air Brake Handbook.pdf
    http://www.meritorwabco.com/MeritorWABCO_document/tp20141.pdf
    Really there are ultra new electronic air supply systems (Knorr Bendix EAPU, Wabco ECAM and other.....), they are smart, they save fuel (for example they use to apply compressor every time you slow down and use brakes), but classical systems are more popular now
    In these handbooks typical systems are shown, but truck makers install additionak tanks, use dual tanks with wall inside and check valve (Freightliner), they use to combine Wabco, Knorr, Bendix and Haldex components.....
    fargonaz Thanks this.
  11. gakid
    6
    Thank you the books were very helpful
