Price of a new turbo on an isx15 2350.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RunningAces, Apr 4, 2021.
  1. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    2017 KW, 435,000 miles, 2016 isx15 2350. I think my turbo is going out and was hoping someone could give me a ball park on the replacement cost. It's probably a good idea to have the actuator replaced at the same time from what I've been reading.
  3. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I believe they run over 3k
    RunningAces Thanks this.
  4. RunningAces
    1,263
    2,513
    Jul 2, 2017
    That's good news, I was thinking this job would be over $10,000.
  5. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    Junk yard turbo... Well under $3000
  6. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    A junk yard Cummins VGT. Now thats what I call gambling.......
    Last I saw the turbo alone was north of 4k from Cummins. No actuator and not installed.
    Shop job out the door with a new actuator will probably run you around 6 or 7 total.
  7. Jaebo74
    433
    1,864
    Feb 4, 2021
    Man that's steep. Thank you for the information. You just helped me decide to not buy a redhead. I'll stick with Mack and Detroit. I'm already paying too much for the redhead at home.
    Dave_in_AZ and RunningAces Thank this.
  8. RunningAces
    1,263
    2,513
    Jul 2, 2017
    To expand, would you guys go to a cummins shop, KW shop, or an independent for an accurate diagnosis and turbo replacement? I assume they might need to put it on a dyno, the problem only really kicks in under load between like 20-30psi.
  9. Jaebo74
    433
    1,864
    Feb 4, 2021
    Cummins or KW, unless you have a good mechanic not affiliated with either that you trust.
  10. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Find a Cummins shop with a dyno. If its not throwing any codes and only acting up under load, they may need the dyno to find it.
  11. RunningAces
    1,263
    2,513
    Jul 2, 2017
    Yup, no codes being thrown.
