Preventative Maintenace
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Dec 21, 2020.
  1. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    Hi
    I have 3 trucks all coming out of warranty and I want to do some preventative maintenance to avoid down time. The trucks are Iveco Stralis (yes I know they arent good) but I was thinking this could be a general question relating to most trucks.
    each truck I try and do about 150k miles per year in, mostly interstate work, weights vary, we do light freight up to heavy freaight.
    I am in Australia and I havent had much luck finding a good mechanic who focuses on what problems could arise, rather they just fix things that are broken. None seem to be good at offering advice on what money to spend so you save money. So you really need to tell them what you want done.
    With a truck that has 500k miles on it, and in good working order, what do you replace before it goes bad? At what stage would you look to do the following things? I own the trucks outright with no finance owing.
    Turbo?
    Thermostat?
    Condensor?
    Hoses and Pipes?
    Air Dryer?
    Radiator?
    Starter Motor?
    Alternator?
    Idler Pulleys and Tensioners?
    Belts?
    Air Compressor?
    AC Compressor?
    Water pump?
    Oil pump/cooler?
    Injectors?
    What do you change BEFORE they go bang and what do you let run out until they no longer work? what do you do at the time of a rebuild?
    The engine themselves have warranty for another 150k miles, so I wouldnt look to rebuild until then.
    Any advise would be appreciated
    thanks
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Where do you run in Australia?
  4. MTMAUS
    222
    175
    Sep 28, 2019
    Based in Sydney, Run between Sydney, Melbourne and Brisbane
    daf105paccar Thanks this.
  5. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    waterpump max 5 y.
    Smart man to do work like this.
    preventative maintenance is the best way.
    black_dog106 and bzinger Thank this.
  6. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Owners manual and manufacturers website are good sources of information you seek.
    I have an N14 .
    Belts and hoses I change all of them when one gets bad.
    Alternator, starter a/c pump, air pressure pump. Change when they go bad. There are signs when these are getting weak.
    Water pump will seep coolant thru the weep hole. Change ASAP.
    Thermostat change when it goes bad.
    Turbo. I changed mine at least 10 years old. I didn't want to wait for it to go bad.
    Condenser, radiator oil cooler change when they fail.
    My radiator was flaking metal internally, 3years old. I changed the radiator, hoses
    oil cooler and the housing the oil cooler mounts on.
    Injectors I change all 6 when 1 goes bad.
    Air dryer every 2 years.
    Oil pump when the mechanic tells me it's bad.
    I see preventive maintenance as an investment.
    Good luck.
  7. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,425
    Jul 4, 2015
    Corn field
    I would not do any of the things just because.
    What I would do however is if you have to make a cooling system repair THEN I would go through and replace hoses, radiator, water pump etc.
    If you lose a brake can then replace the hoses while it’s off.
    If it needs pads and drums evaluate the s cams and slack adjusters.
    if the clutch goes out, put a new main seal in along with new linkage for the clutch, new rear main seal and maybe even have them pull the cover on the transmission? Maybe do u joints and carrier bearing while it’s down?
    When something in the system brakes or gets to the point of repair look at the WHOLE system.
    I wouldn’t just randomly replace a water pump. water pump could easily last as long as the engine.
    Only preventive maintenance I would do would be oil changes and grease jobs and the occasional valve adjustments. Having stuff torn apart by a shop “ just because” is asking for serious trouble.
    lester and xsetra Thank this.
  8. bad-luck
    bad-luck Road Train Member
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    Grease the trucks every 2 weeks, and change the oil at the manufacturers recomended drain intervals. Don't fix things that are not broken.
    Tug Toy and Doealex Thank this.
  9. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    I usually do a complete in frame at every overhead, replace the oil pump at every oil change and when I install new tires I replace all the wheel studs and nuts, wheel seals, bearings, and buy new wheels just in case. After exactly 50,000 brake applications the entire system gets replaced from compressor to the wheel ends for safety’s sake.
    When one light goes out I replace all the lights and bulbs along with their switches to avoid future downtime.
    To avoid any fuel system problems the fuel lines, hoses, fillters and pump gets replaced at every fill up and new fuel caps get installed for added assurance.
