Pressure Relief Valve on an Air Dryer leaks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Iwtbrandh, Feb 12, 2022.
  1. Iwtbrandh
    Iwtbrandh Bobtail Member
    32
    8
    Feb 23, 2020
    I have an air leak on the air dryer's pressure relief valve (It's not a purge valve!). Replaced it with the new relief valve but didn't solve the problem. The truck has been seating for 2 months. Also, it's been pretty cold for the past month or so around here. What do you think should I do? Thanks.
  3. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Probably is not leaking but doing what its supposed to do: relieving pressure.
    Is the truck building pressure on the tanks?
    Big Road Skateboard Thanks this.
  4. Iwtbrandh
    32
    8
    Feb 23, 2020
    no, it doesn't. It can't go above 30PSI
  5. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    Probably a blockage either in the drier cartridge, or in the air line between cartridge and tank.
    Iwtbrandh Thanks this.
  6. Iwtbrandh
    32
    8
    Feb 23, 2020
    Do you think this will solve the problem?
  7. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    No, remove the air line between drier and tank and see if it's plugged.
  8. Iwtbrandh
    32
    8
    Feb 23, 2020
    Ok. I will try that. Thanks
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Bypass the dryer and see if it builds. Connect air in and air out together. If it does, you need a new dryer.
  10. AModelCat
    154,281
    What's the rating on the relief valve? They come in several ratings.
  11. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Those air dryers are the worst I have the twin cartridge one on the Mack I drive. As soon as it gets below freezing it freezes up and either that relief valve leaks or the purge valve leaks. Not to mention it sounds like an airplane taking off when it does pop off.
    Do you have any water at all on your air cans? As soon as I get the slightest bit of moisture in mine is when the problems start. And I drain mine every day
