Pressure in Coolant Tank
Discussion in 'Experienced Truckers' Advice' started by kabusheke2004, Oct 1, 2016.
  1. kabusheke2004
    kabusheke2004 Light Load Member
    99
    36
    Jul 20, 2014
    Virginia
    Hello all.
    I have a 2006 Volvo VNL with a Cummins ISX engine. The egr is deleted.
    Lately i have been getting a STOP engine light driving down the road for critically low coolant level.
    I go to the coolant tank and all the coolant has shifted to the left side(reservoir).
    I open the black top cap and there is pressure in the tank. The coolant levels out after i let the pressure out.
    I had an oil sample today at Speedco to check for coolant in the oil caused by Head Gasket. Oil Sample came back clean.
    Does not overheat, normal oil temp, no power loss, no white smoke in the stacks.
    If anyone may have an idea what it could be i will appreciate any advice.
    Thanks and be safe
  3. kabusheke2004
    99
    36
    Jul 20, 2014
    Virginia
    Forgot to add that coolant tank turning darkish with gummy residue on the sides
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    Could be air compressor
    kabusheke2004 Thanks this.
  5. kabusheke2004
    99
    36
    Jul 20, 2014
    Virginia
    How is it related to cooling system? I don't have building air issues
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Head gasket can still blow without causing oil & coolant to mix -- it just depends on where the gasket fails
    ChaoSS and kabusheke2004 Thank this.
  7. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    From what I been told its gear driven and has coolant that runs with it? But if the seal it worn it could cause air to build in ur tank
  8. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Get the system pressure tested or buy a test kit for head gasket. Got mine from nappa $80
  9. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    Theirs a coolant channel that goes through the air compressor to keep it from overheating. When the compressor fails it will pump all that compressed air into your coolant system therefore pressurizing it to 120PSI or as close as it can get it.
    Quick way to test that is to pull the main line off the air compressor and drain the tanks completely while doing the bottle test on the coolant overflow hose and see if the bubbles persist.
  10. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Wouldn't that be really loud with that line off lol
  11. AModelCat
    154,362
    Well for starters, cooling systems are supposed to be under pressure (like 5-8 psi). The only time its an issue is if it is over-pressurizing from a blown head gasket or failed compressor. It will be noticeable as in there will usually be heavy bubbling in the header tank. If the coolant is discoloured, I would have a combustion gas test done on the cooling system for starters.
