My Predator 3500 does not seem to be charging the battery. It ran low and then lower and then lower until I had to use the pull start.
The battery is pretty low but I'm going to attempt to charge it and then I can check to see if it actually is charging or not. But with a battery that has run down that low certainly doesn't seem like it's charging to me.
So the first question is does anyone know if there is a simple fix for this?
The second question is what battery replaces it? Harbor Freight has a 160CC a battery but I don't know if that will fit the 3500.
Aside from the charging issue the generator has really been great. It's been super quiet and done everything that I've needed.
I would hate to use the warranty for that issue but I guess if I had to I would.
Predator 3500 battery/ charging
Discussion in 'Ask An Owner Operator' started by Dino soar, Feb 5, 2022.
