Pre-Hire drug screen questions.....
Discussion in 'Questions From New Drivers' started by LostMarble, Oct 10, 2010.
  1. LostMarble
    LostMarble Bobtail Member
    4
    Concord, North Carolina
    I'm trying to get into the trucking industry and started off pretty bad. First, I only have a CDL Learners Permit. I applied to SWIFT and started at the academy in Memphis. The first day was of course the DOT physical and drug screen. I quit smoking a month and a half before I went to SWIFT believing I was clean and good to go. I tested positive for THC. Whoops! I was told that I have to go through the SAP process to be considered. $550.00 to start. If I never even sat behind the wheel of a truck before or have a CDL Class A license, how can they take something away that I've never even received yet? It was a Pre-Hire drug screen which I did not pass. How does this effect me for future endeavors with other trucking companies. Do I really have to go through a SAP program before I drive a truck? Anyone know what my options are?
  3. walstib
    walstib Darkstar
    I don't know your options...
    I'd be more concerned if something like that would go on your DAC, hopefully someone more knowledgeable will chime in...
  4. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    since you started at swift, i would imagine you signed a bunch of paper work......this being said, they DAC'd you for a positive drug screen.
    you MUST attend that SAP program at your cost i believe. you will find it hard from this day on to gain employment since you pulled a positive.
    and they can take away anything they want, you screwed up, not them......
    i do hope you learned a lesson, stay off the shiot.......
  5. Laid_back_fella
    Laid_back_fella Bobtail Member
    20
    Oct 6, 2010
    San Diego, CA
    Maybe it's bad for me to say this but, you should of went to a smoke shop and bought a synthetic urine kit for $30 bucks, hey i aint gonna lie when i was younger and had stress coming from family and my old lady i would smoke a lil Mary Jane. I used the kit a few times in the past for pre hires i KNEW i wouldnt pass due to smoking. Basically you get a kit that comes with the synthetic urine, a small heat pack that last 10 hours and directions, before the test you wrap it below your sack with the heat pad on it, then when they send you into the bathroom you drop your pants take out the bottle a squirt it into the cup. The heat pad keeps it around 100 degrees which is what they are looking for, YOU PASS EVERYTIME:biggrin_2559:
  6. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,054
    Jul 15, 2007
    TEXAS
    Here is two links that concern you>> http://www.fmcsa.dot.gov/rules-regu...csr/fmcsrruletext.aspx?reg=382.605&guidence=Y
    http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&rgn=div5&view=text&node=49:4.1.1.1.14&idno=49
    I'm sure swift has reported you and by regulation, you have to complete a SAP program.
  7. LostMarble
    4
    Thanks for the advice. I have quit the shiot but I still have one concern. How can I complete the SAP return to duty process, when I'm not working for a trucking company? Do I simply go through the process while unemployed? It just seems very unproductive and a waste of time for the individuals making sure the process is being met under the regulations DOT set forth. So.... I complete the SAP process, will this erase my mark on DAC? If not, what's the point? I kept hearing that there are over 300,000 truck drivers needed and the number is going up every year. With this kind of demand, I would think that trucking companies would be a little more lenient towards truck drivers or individuals trying to get into the industry.
  8. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    :biggrin_2556: Go too Gary , Ind and i can gurantee you at that old k-mart parking lot there, there is at lest 50-89 trucks parked in there every night i go by , smoking know what all and the lot lizard's running rampant, i wacth em take off while waiting at the light and you can tell there so high , just by the way they drive, if you see anyboby shift ten times in block and you can count the puffs of smoke every time they shift, although not very good thery , but close enuff, but yes the ins are telling them the drivers must be clean or they be a risk factor involved, do you want a truckdriver high on know what all, right on your bumper cause his load late and hes ridding your asset then pass you on double yellow line going up a hill, ya thats what there looking for, so get clean up , spend the 500 or so, practice practice and by that i mean , put a ad on craiglist , asking dosnt hurt ether, but mayby someboby will hire too drive dump truck, then as baby steps up the ladder, no trucker started at the top of ladder, we all took our baby steps , or start from the bottom of ladder, so ask around get a job ,start driving a dump truck for 3 years, show your a hard worker and a clean worker, if you can't quit smoking , then spend anthor 567 or so too get into rehab if you want too do this, then in same company ,mayby with luck and clean after 3 years get your cdl class b , this will get you in a tractor and side dump, mayby, side of the company, and keep practing, this may or may not work , you can only try , sorry for long post, but thats only way i can explain myself :biggrin_25524: Everett.
  9. Rerun8963
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    IF YOU WANT A JOB, YOU HAD BETTER DO IT......!!!!! and by the way, THERE IS NO GUARANTEE you will get your job back. the EMPLOYER only has to refer you to the SAP.......but IS NOT REQUIRED to take you back.....!!!!!
    you wanna job.......??? YES.....you HAD BETTER DO IT....IF NOT.......NO EMPLOYER WILL EVER TOUCH YOU.....!!!!! YOU'LL HAVE A LONG DAC RECORD ON THIS POSITIVE TEST, with NO SAP......??? are you kidding me......????
    YOU BROKE THE RULES, if you think its unproductive, then QUIT NOW and go someplace else, because you AIN'T GONNABE driving a truck
    NO, IT WILL NOT......
    ARE YOU KIDDING ME.......?? the POINT BEING, you got your shiot together.
    not entirely true........we are STILL in a recession, there ARE STILL drivers unemployed, that CAN PASS a drug screen......
    NO, NOT when it comes to POSITIVE drug tests......
    you are making excuses for your transgressions, from this point on, i feel absolutely NO sympathy for you or people LIKE YOU that think trucking is going to be the way YOU WANT IT TO BE.........well it JUST AIN'T SO......if WE HAVE to follow the rules, SO DO YOU........:biggrin_25516:
    good bye, good luck, "i'll take fries with that"..........
    celticwolf and Everett Thank this.
  10. thelastamericanhippy
    thelastamericanhippy Road Train Member
    1,038
    311
    Jul 10, 2010
    jacksonville, fl
    First,
    get a copy of your DAC...........
    then proceed to step #2................
  11. Flying Finn
    Flying Finn Heavy Load Member
    972
    556
    Jun 22, 2010
    Ontario, Canada
    Sounds like another wannabe driver that watches too many old movies about driving thinking that is what the industry is like.
    In Canada, you have to sign off on paperwork that allows the company to get your old drug screening test results. You can say no, and they can say "hit the road". Also with a formal record of usage it will most likely be more difficult for you to get a FAST or TWIC card and cross the border in either direction. The FBI/DHS and RCMP will suspect that as you have a record of using then you are at risk of trying to smuggle drugs across.
    Likely not what you want to hear, but, you messed up, you have to pay the piper.
