Power steering pump
Discussion in 'Western Star Forum' started by n4ane, Dec 6, 2020.
  1. n4ane
    n4ane Light Load Member
    132
    59
    Aug 28, 2020
    So I am replacing my power steering pump due to it constantly leaking motor oil. I ordered the pump online with part number from dealer. I have read on several places here where people are putting 15w40 in the power steering system instead of power steering fluid or atf. When I opened the box and pulled the directions it says to use a atf with low foam. so do I need to use atf or just put motor oil in it since that's whats already in the system? I would like to flush all the old oil out just so its all new fluid.
  3. n4ane
    132
    59
    Aug 28, 2020
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    So the pump is just a low pressure gear pump. It will work with engine oil or atf. The atf has better clutch plate wear properties and a lower pour point.
    n4ane Thanks this.
  5. AModelCat
    154,580
    Should be able to use either or. I would stick with whatever is currently in the system to avoid mixing fluids. You'll never get 100% of the old oil out unless you completely tear down the steering box.
    n4ane Thanks this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    It really went by the steering sector mfg recommendation.
    Sheppard used 15 W 40.
    Ross - TRW used ATF.
    A major I worked for had new trucks come in with Ross boxes. Ross said they would not honer warranty if ATF was not used. Company said we have over 300 shops and have no reason to inventory ATF. Even the service trucks are manuals. If we have to add all the inventory for your steering boxes we will make a point not to buy new trucks with them anymore. Then 15 W 40 was fine.
    The 2019 Pete here with a Sheppard is labeled for ATF.
    Your concern is the warranty of your new pump. Flush the system replace the filter and use the fluid they specify.
    An exception to that could be a Saginaw or ? ( some other unusual sector ) . They can have a be reaction to anything but P/S fluid.
    Rideandrepair and n4ane Thank this.
  7. n4ane
    132
    59
    Aug 28, 2020
    How do I know it its a sheppard or a ross?
    Rideandrepair Thanks this.
  8. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    Name is normally cast in the side of the box or post a picture.
  9. n4ane
    132
    59
    Aug 28, 2020
    Ok I will take one tomorrow
