Power steering oil overheating?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by droy, Dec 18, 2014.
  1. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    2007 T800 C15 Accert
    About a year ago, started leaking @ output shaft seal, R & R seal, then again month or so later, cannot seem to stop oil leak, also seeping at suction, return fittings (Boss). Replaced steering box, all hoses, all O rings; solved leak at seal, still seepage at the Boss O rings. Last week, started leaking at output shaft seal again, replaced power steering pump, all hoses, all O rings, 2000 mi later, seepage at the O rings, output shaft seal. WTF???
    While I haven't put a temp gun to it, am almost sure I have an overheat problem in the power steering system. Hoses seem to harden prematurely, & the leaking, along with steam coming off the components when sprayed with water based degreaser are clues. I can't figure is what the heck is making the oil overheat??? Spraying the engine, air compressor, etc. does not produce the steam vapor like the power steering. Using engine oil in the ps system (Scheiffers 7000 15w40), Oil is fresh, PS filter prolly has 50k mi on it, gonna replace it tomorrow; would appreciate any suggestions.
    Thanks in advance
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Can't help. Never heard of this problem. Wow! This would pizz me off to no end!
  4. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Have you always run oil in the PS? I know if you switch from hydraulic fluid to oil and don't purge all the hydraulic oil out of the system you could possibly have foaming problems, which maybe could cause overheating. Does the fluid look foamy after you been driving for a ways?
    Is the power steering noisy? maybe some air trapped somewhere? Changing the filter sounds like a good idea to me.
    Maybe the old PS pump left some crap in the lines?
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Have you replaced the filter? A clogged filter will cause overheating.
  6. 201
    201 Road Train Member
    12,047
    24,590
    Apr 16, 2014
    high plains colorado
    Power steering, like any hydraulic device, it's imperative that the system be completely flushed clean. Sounds like there's still metal in the system. I was told engine oil was fine, but that was years ago. And hydraulics do run warm.
    Interesting power steering story, I had a '82 Western Star conv. with PS, and one day driving down the road, I hear this, POW, and nothing else. So naturally, I pulled over, opened the hood, oil EVERYWHERE, and the dipstick on the reservoir was gone. So I called a shop I trusted, the SM asked, "What color was the oil"? I said, "pretty dark", he said, "the seal on the PS pump went out, and oil from the motor was being forced into the PS reservoir, and it filled it up and blew the dipstick out". A new pump, and I was on my way.
    Skate-Board Thanks this.
  7. uvulabruzr
    uvulabruzr Bobtail Member
    36
    13
    Nov 1, 2014
    CANADA...EH
    Is it the small plastic reservoir? Severe duty with assist ram on the right side? PS cooler?
    We had a truck doing the same and ended up putting a larger reservoir on it, more volume =lower temps.
    Also I think you should be running automatic trans fluid in it, not engine oil.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    In heavy applications 15/40 works the very best, we found that out in the twin steer cement trucks. also a common problem with a system overheating is the driver continually moving the wheel, we had one unit continually had seal and pump problems I went for a drive with him and he continually was moving the wheel back and forth, I asked him why he felt he had to do that he said it gave him something to do, I told him he was driving like an Englishman and try to keep the wheel as stable as possible.
    We had heavy duty application that we had to install the larger tank and move the tank down to get a cooler air flow.
  9. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    You can buy one of those meat thermometers and stick it into the p/s reservour and see what temps it is actually building to. Excessive temps are being caused from restriction and/or constant use. If you have seized or very stiff steering components, like kingpins, the steering will over heat. Jack up the front end and move the wheels side to side by hand.
  10. 201
    12,047
    24,590
    Apr 16, 2014
    I didn't have to worry about any of that with the ol' Pete (below) It had manual steering.:thumbup:
  11. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    the filter is inside the reservoir on a kw its a nelson filter 57904 and on the reservoir it states to use dexron mercon atf only
