power inverter
Discussion in 'Volvo Forum' started by butterbean1977, May 6, 2014.
  1. butterbean1977
    butterbean1977 Bobtail Member
    15
    mississippi
    Has any one had any luck with those inverters from love's truck stop the 2000 watt one
  3. jabekins
    jabekins Bobtail Member
    37
    17
    Apr 16, 2014
    Warrenville,IL
    They are all about the same just look at Watt's 2000 is peak they last a long time it you don't over do it.
  4. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    i have a 2000 watt Loves inverter
    no problem but only been 6 months
    i blow the fan out regularly to keep the dust out so it cools properly
  5. sherlock510
    sherlock510 Road Train Member
    1,066
    1,057
    Jul 26, 2011
    Intercontinental.
    They do work, 1 yr+ with mine.
  6. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    Just as a contrast I've bought and been thru a few of the inverters that truckstops sell. They never lasted for me so after going back on the road I decided to shop around and I bought a 1500 watt Go Power inverter from amazon. This thing is built like a tank. Much bigger than the TS ones. The cables alone are as thick ad you can get but so far it's done a great job.
    There's all ranges of prices and mine wasn't cheap but is nowhere near the most expensive.
    You just have to go with what you think is best. Modified Sine vs Pure Sine.
    Good luck
  7. butterbean1977
    15
    mississippi
    Thank you just got a new truck of my on so trying to save some money
  8. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    If your going to watch TV, use a Microwave and maybe use a lap top at the same time and you will now and again My advice is you will be better off with a 3000 watt 3500 peak inverter. Pay the extra. That is what I use and have had it for 5 years and no problems Also Forget the garbage wire they give you . Go to a welding shop and get welding cable. Have ends put on. You can weld all day and never get the cable hot. No worries on a truck. The red and black junk cable in the box is mostly used for stereo and amps for cars. If you shop around try to get an inverter with remote on off switch You will be glad you did. Other than microwave, TV,DVD player and two laptops we use ours to air up the air mattress.
    Important. Put a fuse in both lines. Hot and ground. Will protect your truck from fire. best of luck in your search .
  9. freddyb
    freddyb Light Load Member
    81
    44
    Aug 22, 2013
    dumas ar
    I have a 1500 watt one like the ones from loves bought off ebay. trying to run just a 700 watt microwave on it. keeps giving the ovp on display. any ideas on what may be wrong? I run a small flat screen also but have a 400 for that. help
