Power inverter for portable ac
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Trevor19, Jul 15, 2024.
  1. Trevor19
    Trevor19 Bobtail Member
    7
    5
    Feb 1, 2023
    I’m looking for a temporary solution. My air conditioner went out so I’m in the process of acquiring all the stuff to replace the whole system. So in the meantime, I thought, hey I’ll run a small portable ac off my inverter. The portable ac works but does not stay on, meaning it will turn on, start cooling, but it draws too much on my inverter (might be a little tired) and I get the low voltage cut out on the inverter. Truck volts don’t drop at least from what I can tell. So I’m wondering if this is just impractical or if I had a more powerful inverter, could I get this to stay on.
    Current inverter is a older cobra 1500w
    Portable ac is a 5k btu, 870w input cooling power, cooling current 7.7a, L.R.A./R.L.A of compressor 35a/ 6.58a, F.L.A. Of fan .78a, rated current 8a.
    small fridge and microwave is also run off the inverter. I would not use the ac and microwave at the same time.
    I will only be using the portable ac while the truck is running/idling because I’m sure it would love to drain the batteries. Do y’all think a 3k inverter will do the job? Or?
  3. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    Get a tiny gas generator with 2kw output. Problem solved till AC fixed. Many are running them with window AC units, saves on idling time and fuel.
    Trevor19, scottied67 and Bean Jr. Thank this.
  4. Trevor19
    7
    5
    Feb 1, 2023
    That is not a bad idea and I will probably keep the ac unit afterwards and do this.
    my immediate problem is with wanting to run the ac during the day so that’s why I was wanting to go the inverter route. Any idea if the inverter will run it as long as the truck is running.
  5. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    I would think the inverter should be at least double the voltage of the electronic device's needs.
    Trevor19 Thanks this.
  6. goga
    894
    1,586
    Nov 11, 2021
    Earth..
    Alternator will not sustain the current drown from batteries to charge them up quick enough for longer than few minutes. Fuel used to turn alternator worth more than these temp solutions. I run 5kw inverter in my rig, and I'd not put it through so much current running AC unit, plus gallon an hour of fuel. 100 hrs will buy me generator.
