Power inverter(400w) wont power my desktop pc
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by cturn44, May 20, 2020.
  1. cturn44
    cturn44 Bobtail Member
    4
    So I do a lot of video editing as part of my side job, and I wanted to get my computer running on the inverter's power supply. When I try it though it will power up for a few seconds and then trip the circuit breaker and snap off. So I went and got a ups(uninteruptable power supply) to both get me through the power on process and deal with the whole "simulated sine wave" issue, but again it just sucks up too much juice. Has anyone had similar issues? Can a higher end laptop for editing be powered by an inverter? I don't wanna invest in one unless I'm sure it will work.
  3. Brandt
    Brandt Road Train Member
    4,409
    5,948
    Sep 17, 2012
    Sounds like you need more power ! If you 400w inverter plugs in to 12v plug in truck dash those can only power 150w. So that might be the problem. I have not look at lap top power requirements lately. A Pure Sinwave is better for computers not really required I would think. I ran laptops on regular inverts no problem. Look and see how much power you laptop needs if it's high end gaming laptop or video editing company it probably just need more power. I can imagine 400w can't power it but you would have run the power cables directly to batteries to get 400W.
  4. cturn44
    4
    Ok can you explain a bit how i go about running cables directly to the batteries? And did you mean 400w CAN power it? It sucks I go on two week trips across the border can't test new things out often.
  5. cturn44
    4
    Ok can you explain a bit how i go about running cables directly to the batteries? And did you mean 400w CAN power it? It sucks I go on two week trips across the border can't test new things out often. (forgot to reply with the last post)
  6. Brandt
    4,409
    5,948
    Sep 17, 2012
    I would look at the power brick for the laptop and see how many Watts it is. Then you will now of it's need more power then the inverter can make.. I had some basic laptops they only needed like 90watts or something. Running cables to the batteries is more then I know. I see lot of people need like 2 gauge wire or 4 gauge. I have seen the yellow inverters at truck stops they sell wires to hook them to batteries. Basically you can draw more power then the cable can handle. They get hot and start a fire. Or they rub when driver pass then thru the floor because they don't put any insulation to protect the cables and they get a fire.
    I'm sure someone on here know how to do it correctly. It it your truck you can do that. If it's a company truck they don't like that stuff being done.
  7. Brandt
    4,409
    5,948
    Sep 17, 2012
    Love's sell some cable not sure they are the best cables but they are 2 gauge and 3 gauge and 4 gauge depending on power you need and length of the cables you need
    Portable Power Inverters
  8. GrimOxford
    GrimOxford Bobtail Member
    5
    May 20, 2020
    The sad part is most people do not understand the proper gauge needed to begin with. If you are trying to run a 1500w inverter you need a minimum of a 2 gauge but ideally you should put 1/0 or 2/0 in for better over current and heat protection. As for running them directly to the battery compartment, it will require drilling a decent sized hole in the floor and a lot of finesse to get them there neatly and without chafing the wire.
    Brandt and 86scotty Thank this.
  9. cturn44
    4
    Thanks for all the usefull info. Well I am a company driver a pretty new one actually so I don't think I should go messing with the batteries like that. It's funny though I can run multiple laptops and a cooker and a tv at the same time with the different outlets hooked to the inverter, but the big computer alone is too much. I almost wonder if theres some way to recombine the power alloted to the different outlets somehow. Have you ever heard of doing something like that?
  10. GrimOxford
    5
    May 20, 2020
    Your desktop pulls too many watts for the inverter. Period. Most desktop computers are a MINIMUM of 500w while bigger performance ones are in the 1800w+ range
    Dieselboss Thanks this.
  11. 86scotty
    86scotty Road Train Member
    4,375
    11,615
    Aug 27, 2017
    Appalachia
    You won't for long. Any inverter of worth is going to require cables the size of your fingers to move power. It's also going to require the truck or APU running to support this. Real power is not free. Most people don't have much of an understanding at all of how much AC power we take for granted, especially in America where it's cheap and plentiful from the handy little plugs in our homes. Your average hair dryer or toaster pulls more power in one minute than lots of inverters can handle or can be replaced by solar panels sucking up rays all day long.
    Dieselboss and GrimOxford Thank this.
