Potential flaws with the collision mitigation systems (CMS)
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Moving Forward, May 27, 2022.
  1. Moving Forward
    Moving Forward Heavy Load Member
    737
    727
    Jan 14, 2014
    New England, USA
  3. Arctic_fox
    3,861
    19,418
    Sep 16, 2016
    I took it off my truck because it nearly caused 3 major wrecks in a 2 month period. After it freaked out and hard locked my brakes on i80 in NE while it was snowing and no vehicle was within 1500 yards of me causeing me to almost jack knife...well i took it off my truck for a reason. Another "fun" one was i went into a scrap yard and it kept hard locking my truck because it read the scrap as me about to hit a vehicle. Had to actully unplug it then go to a dealer and pay them to clear the check engine lights that caused just to unlock my brakes.....and this 2 days after i paid the dealer to adjust and calabrate it.
  4. Moving Forward
    737
    727
    Jan 14, 2014
    New England, USA
    I'm a company driver and can't take it off the truck, but it's both frustrating and potentially dangerous the way it will jam on the brakes for a #### road sign. I've had it happen to me numerous times on I-95, and sometimes the vehicle behind me was close enough where I was concerned they might run into my trailer... but thankfully they didn't. It's hard to believe the Feds are looking to make the CMS mandatory for commercial trucks with this kind of issue clearly happening.
  5. Ffx95
    Ffx95 Road Train Member
    1,368
    2,627
    May 18, 2017
    I stopped using the cruise control with these newer trucks. I’m governered at 65 so I just keep the foot down when the speed limit allows it. Throttle pedal overrides the collision mitigation system.
  6. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    My 2022 Volvo VNL760 was sent without the sensor thingy due to supply shortages. So, haven't had any issues with this in my current truck. My old truck, a 2019 VNL760 had this problem. But, it never slammed on the brakes so hard that it caused a potential accident. And, as mentioned by another,, if you don't use the cruise, it doesn't engage the automatic braking and use of the accelerator pedal overrides it also. So, with my Volvo at least it was only an occasional annoyance. I've heard that on Kneworths it can be a real problem, but I have no first hand experience with it.
    In my opinion, it is one of those bean counter safety features that only looks good on paper and reports and charts. But, for the actual drivers, it is nothing but a potential disaster waiting to happen and has no place on a CMV.
  7. tscottme
    tscottme Road Train Member
    It's junk. I started reporting every phantom panic stop of the CMS to my company safety hotline for dangerous situations. Each time they had to be slowly and carefully convinced I had not just had an accident. The camera can trigger a panic stop and the radar can trigger a panic stop. If either the camera or the radar gets fooled the system attempts a panic stop. It is not just the radar, either system can trigger an event. Create a papertrail, your heirs might need one to win their lawsuit when you are murdered by your truck.
  8. MACK E-6
    48,113
    219,512
    You may not be able to take it off, but you could move the license plate in front of the radar while nobody’s looking, not that I would advocate anything of the sort at all. :biggrin_25520:
  9. tscottme
    If you do that the cruise control is disabled. My Freightliner's forward sensor would get covered with frozen slush/ice, report the sensor has failed. I would use the buttons on the CMS display to cycle through all of the system pages. Then I could turn the cruise control back on and use it without the adaptive cruise control/CMS function.
    cycle through all the pages of the CMS and then turn cruise control on and off a few times and then turn cruise control on and set the speed. I don't remember the exact sequence of button pushes, so do every possible combination of CMS buttons and cruise-control on/off.
    Moving Forward Thanks this.
  10. MACK E-6
    48,113
    219,512
    Well, when the radar gets blocked on my Pete the cruise works in what it calls “speed mode only”. That mean the cruise works the old way without the new annoyances.
  11. Flat Earth Trucker
    4,053
    14,889
    Nov 19, 2018
    Mine displays false stationary object warnings up to five times per day. It brakes with cruise control on for vehicles that are leaving the road.
