Post trip inspection mandatory?
Discussion in 'Trucking Industry Regulations' started by Life on Wheels, Jul 23, 2020.
  1. Life on Wheels
    Life on Wheels Light Load Member
    196
    177
    Aug 17, 2019
    New Orleans, Louisiana
    I was told that DOT does not require a post trip inspection if you will be driving the same truck the next day. Does anyone know if this is true? I guess there are two scenarios that could apply here. One is if you are a local driver who parks the truck at a yard and goes home and returns in the morning. The other is an OTR driver who is spending the night in the truck. I know all companies require a post trip, but I'm wondering if DOT rules say that you must show "on duty" time at the end of your log with "post trip inspection" annotated. Can y'all help me out with this?
    truckdriver31 Thanks this.
  3. Judge
    84,390
    Just flag it, /post trip, just don’t show any minutes
  4. Lennythedriver
    Lennythedriver Road Train Member
    2,203
    7,297
    Feb 14, 2020
    You can inspect your truck five times for three hours a day each but if you don’t log on duty for that required minimum 10 minutes, it didn’t happen. And yes, the DOT will cross reference the time you submitted your inspection with the time on your log. I inspect my truck and trailer as often as I can. I’m always checking things...Yes it’s true sometimes while I stop driving at three in the morning at some dark truckstop I’m not gonna get out and crawl around but I’ll still log it. Of course in the morning I will get out and check everything before I start driving.
    truckdriver31 and Life on Wheels Thank this.
  5. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    PART 396—INSPECTION, REPAIR, AND MAINTENANCE
    §396.11 Driver vehicle inspection report(s).
    (a) Equipment provided by motor carrier.
    (1) Report required. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated, except for intermodal equipment tendered by an intermodal equipment provider. The report shall cover at least the following parts and accessories:
    [snipped]
    (2) Report content.
    (i) The report must identify the vehicle and list any defect or deficiency discovered by or reported to the driver which would affect the safety of operation of the vehicle or result in its mechanical breakdown. If a driver operates more than one vehicle during the day, a report must be prepared for each vehicle operated. The driver of a passenger-carrying CMV subject to this regulation must prepare and submit a report even if no defect or deficiency is discovered by or reported to the driver; the drivers of all other commercial motor vehicles are not required to prepare or submit a report if no defect or deficiency is discovered by or reported to the driver.​
    Emphasis added.
    Note the requirement to do a post-trip inspection. Also note the exception to produce a report if no defects found. There is no exception based on continued operation.
    There is no such thing as minimum or maximum time requirement for inspections.
    Dale thompson, Eddiec, jsnell and 3 others Thank this.
  6. Life on Wheels
    196
    177
    Aug 17, 2019
    Well that answers it. Thank you!
    Eddiec, truckdriver31 and not4hire Thank this.
  7. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    what does the green book say
  8. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    If you really want to get technical (and some people do), the regs. do not say you have to do an inspection, they only say you have to prepare a report. And you don't have to prepare the report if you don't find any deficiencies. I guess you could not do an inspection and not prepare a report, but a professional wouldn't do that.
    Just thought I'd cover this for the hair-splitting beppos.
  9. roshea
    roshea Road Train Member
    not4hire's post was the green book
    not4hire and truckdriver31 Thank this.
  10. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    yea saw that. it just puzzles me people dont look in the green book
  11. Brandt
    Brandt Road Train Member
    4,403
    5,936
    Sep 17, 2012
    My understanding is, it's required but their no set time limits and if you don't find anything wrong. Then you don't have to fill out the form.
    Some trucking company could have more strict rules like you have to show 10-30 minutes
