I have a ‘15 cascadia DD-15, former prime truck. I mention this because I know they order without certain items like water separators etc. clutch was replaced July ‘22 and a few months ago it started going into gear tough once stopped. If you are loaded and slip it into 2nd as you come to a stop there’s no issue going to 1st but if you are totally stopped it doesnt want to go into 1 or R. I’ve tried letting up slightly, throttle, etc. I looked under and the hose that should exit the plate is not there. I removed that and there is no visible zerk to grease the throw out bearing. I did feel around and located one. Let’s say at the 2:00 position just about a bolt but you can’t get to it with a grease gun as far as I can tell. Any ideas, please?? Also I checked the clutch brake. Not sure of the surface but it only moves back and forth maybe 1/4-1/2” like it should when you try to rotate it. Thank you.
Possible throw out bearing issue
Discussion in 'Freightliner Forum' started by RItrucker36, Oct 8, 2023.
Does the clutch need adjusted?
Grinds to point you almost can’t get it in. I’ve been able to slowly slide to reverse and then it will go to 1st.
If the clutch is adjustable, adjust TO Brg to clutch brake to 1/2".Star Rider and Last Call Thank this.
