Is anyone using one or have you used one that does not need to be connected to electricity. Would you by it again or would you try something else? Considering buying one to help knock the chill off when I absolutely have to do repairs outside in extreme temps. Several in the $300/$400 range look good, but I have never owned one so I don’t t know what to compare it with.
Portable Salamander Heaters Diesel/Kerosene
Discussion in 'Ask An Owner Operator' started by Banker, Dec 17, 2022.
Page 1 of 3
I've never seen one that doesn't need 110 to run the fan or the ignitor. That being said they can be a life saver. Some people are sensitive to the fumes so pay attention to that.
You could always put a generator on your truck to run one.
You could run lights and whatever else you need too.
I have work lights that are not LEDs. They're halogens and they create a lot of heat if you put them near where you are working. -
Siinman Thanks this. -
cke, Siinman, Banker and 1 other person Thank this.
My Honda eu2000 generator weighs in at 46 lbs and will store in the cab with no stink. The less expensive Harbor Freight model is 3 lbs heavier. Never used the HF model to say anything about it. Main downside: runs on gasoline. Probably not a big deal if not run all the time, eliminating the need to carry/fill a gas can. Runtime spec is 3.2-8.1 hrs on a tank, depending on load.
That heater weighs around 40lbs plus up to 13.5 gal fuel for possibly 95 more, so that's not nothing either.
Unless you're doing repairs like this a lot while on the road, this seems like a lot of hassle to stow and use for a just in case scenario. -
I tarp the truck and use a propane/lpg heater. If the mechanic doesn't have time.
Diesel/kerosene heater fumes give me a headache.
I have used several different units, all of them needed electricity to operate.cke, Dino soar, Siinman and 1 other person Thank this. -
We call it a Nipco heater or many call it a salamander heater. If you are working outside in the open yeah if you are very near it or in front if it you will be very warm. If not close you'll be cold again.
I don’t generally do a lot of work outside in the cold, but occasionally I have no choice. Today was an example of a couple hours in the cold wouldn’t be as bad with some direct heat blowing on me. Maybe something will be better than nothing.
RedForeman and Siinman Thank this.
Page 1 of 3
