Portable indoor butane heaters
Discussion in 'Ask An Owner Operator' started by haider99, Nov 14, 2018.
  1. haider99
    haider99 Medium Load Member
    685
    108
  3. Ridgeline
    22,385
    116,236
    You have to keep a window open in the sleeper to use it, it produces a good amount of heat but also a good amount of CO2 and water.
  4. tscottme
    tscottme Road Train Member
    The RVers say they work very well, but eventually break. Also with butane/propane heaters they generate moisture while they heat. You have to ventilate well or you will have moisture problems.
  5. 86scotty
    86scotty Road Train Member
    4,462
    11,949
    Aug 27, 2017
    Appalachia
    That is a propane heater, not a butane heater. I've used them overnight in a camper with no problems. You'll get advice ranging from 'you could die' to 'you'll probably live'. My advice? You'll probably live.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    No.
    I have a rule nothing that contains a fuel supply like Butane etc under pressure in the sleeper. You cannot exchange fresh air fast enough to prevent poisoning and eventual death via displacement of oxygen in your blood.
    What I do instead is carry a pair of Atlantic Storm Lanterns that are enclosed, with a wick and carry maybe a couple of cups worth of lamp oil or similar. Light them off, open the vents and one window for airflow and corral the heat as best as youre able. It's not much, but with a absolute dead truck, provided you are not hazmat at all, you might survive the night with one or two of these. Storing lamp oil itself is a complication, best addressed by carefully selecting seriously strong containers capable of making sure that it will never leak or get breached bouncing around in the side box.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Sounds like a good way to get CO poisoning...
    Just have the espar or webasto installed, it's one of the fastest roi in this business, and a must have for operating in winter, especially up here in the great white north. Have it done when you're on vacation. Easy.
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    That doesn't inspire confidence.
    86scotty Thanks this.
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    No way I would run something that emits carbon monoxide in an area as small as a truck sleeper. Yeah, you can crack the windows, but doesn't that defeat the purpose of the heater in the first place?
    Swiss Mountain Dog Thanks this.
  10. mpd240
    mpd240 Road Train Member
    1,540
    3,623
    Sep 17, 2011
    Minnesota
    They make co2 detectors. I had a a fire alarm co2 detecror in my sleeper. I idled my truck or used the bunk heater in winter. Every year you hear about truck fires or guys dying from co2 poisoning while I ideleing. It cost like 20 bucks at Walmart.
